Recommendation for a "cheap" second 50mm?
krötenblender
10:34 AM
Germany
Hello
I'm going to get a Nokton 1.1 and although of course I know, one should only use the Noctilux on the M9... 🙄, it is currently out of reach for me. But the Nokton is too big and heavy for, to have it all the time with me. On the street, I shoot with f8 or even more closed anyway, so I do not need the 1.1 there.
My question now is, what other "cheap" 50mm can you recommend? I have no problem, if it starts at f2.8 or even f3.5, if it is M39 or M. I already have another russian collapsable 50mm, which I got for about 20€ and it is mostly good enough for the street, but it's mechanics (aperture ring and focus) are not very smooth, so I like something else.
Thanks in advance for serious recommendations.
I think the standard answer around here for a 50mm lens that is a 'step up from FSU' is the Canon 50mm 1.8. I have one, great lens, deserves all the praise it gets particularly when found for around $150.
I really can recommend the Leitz Summitar 2/50 and if it needs to be really cheap (=affordable) you should look for a Jupiter-8 2/50.
Depends what you mean by cheap, cheap to buy or cheap as in rubbish. For what it does the 50mm Elmar M (thats the latest version) is as cheap as you will get for a great lens, and most definitely something different to the hulking CV f1.1!
Steve
I don't really know... I think, about 150€. (Preferably less for the intended purpose)
The Canon f1.8 sound interesting, but currently there seems to be only one on *bay for $500... No way. 😱
going rate for nice Canon 50/1.8 is around 130-150 USD or less 😉
you will see outrageous BINs for every lens, just about.
The Canon 50/1.4 is about 300USD or less.
all that said, why not spend a tiny bit more for something serious, like minolta or leica 40/2.
These are tiny lenses and incredibly sharp. About 4-500 USD.
They are also very easy to sell if you need to.
Both are gorgeous lens....
My experience with canon 1.8 is "WOW"
for that amount of money...i think i picked up a precious...
then i jump into a 50 1.4 to see wats de difference...
These are all shots wide open....its amazing sharpness and the tones and contrast on black and white is nice...
the canon ltm 50/1.8 (chrome version) is a delicious lens. it's the 50mm i take out when i want a 50mm. the dr cron and 1.5 nokton should bully it badly when i'm not looking...
