Gilo25
I recently noted that the lines of the range finder get aligned at a distance which is not the actual distance. In other words, when the focus ring on the lens shows a distance of 1 meter and the actual distance from the subject is 1 meter (measuring from the front of the lens), the lines in the range finder are not aligned, but they do get aligned when the actual distance is reduced to about 88 or 90 cm.
At a distance of 3 meters the difference is more or less still there.
Above 20 meters, the lines seems to get aligned when the focus ring is set to infinity. I tried with a Summicron 50/2 and with an Elmarit 90/2.8 and the results are the more or less the same.
Is this normal or does it mean the range finder is misaligned?
Thanks to everybody
Thanks to everybody
