Frank Petronio
I've been burned by getting the Printfiles that hold 7 rows of six frames and then finding the pages won't fit my normal 3-ring archival binders...
What works best?
What works best?
What works best?
I use the 7 rows of 5 frames...I know that I will most likely have some frames left over (I normally get 38 shots on a 36 exp. factory roll...)
I take the extras and put them in another page with other leftovers...but only after looking at them to determine if they are worth keeping...
These do printfile 7 rows of 6 with room to spare: http://www.bhphotovideo.com/c/product/140932-REG/Besfile_B_9051_Archival_Binder_With_Rings.html
2. ARCHIVING: When shooting film, my negatives are stored, sleeved, in FilmGuard Pro-Line negative pages (item #PL24920). This is one of few neg pages that can fit sleeved negs besides the Print-File Ultima series. My choice of Pro-Line was based on a long, complicated search process. The issue seems to be one of strip length. A 36-frame roll usually works out to 6 strips of 6 images, but - and here's the important part - there is no sealed 3-ring binder available that can easily fit a six-frame wide negative page. Yeah, I couldn't believe it either. I happen to eschew "open" binders, so you can see my dilemma. I thought about cutting the Ultima pages down width-wise, but then I'd have six strips of five frames, which would be a waste of 6 frames per roll (I shoot mainly 135-36 films). Instead, the Pro-Line pages fit seven strips of six (they're taller), and so when I cut them down (by about an inch in width) I end up with seven strips of five, which only wastes one frame per roll. As a consequence, I always wind on to "2" before shooting. All these pages are captured in ImageSafe locking binders (or the equivalent; these go by a couple different names. They're the biggest ones I've been able to find). By the way, even if I went with an "open" style binder, the only one that would fully fit - and protect - 6-frame side pages is the PrintFile "G" series album, which is pretty pricey for the flimsy binder it is.
Really? That's good news if so, because I've had a devil of a time trying to sort out the morass of incompatibilities in this area.
--joe.
Yes, they are all I use for storage. They accommodate 7 row/6 neg with room. They are pretty dust proof, as well. They also come in 3 diff fashionable colors, black white and gray! 🙂
