andy_v
I'm especially interested in 25/2.8 behavior.
Thank you.
Thank you.
I have not tried the 25mm, but the 21mm f4.5 works fine. I have a few sample shots here:
http://flic.kr/s/aHsjwpJAmd
Thanks, so this is what raw files can output. Since the gxr raw files are dng, I guess no specific raw converter is bundled with the camera, so the moiré treatment will depend on existing softwares.On that first Tokyo shot, I think it's because of my post processing. Here's a link to another full resolution shot - it seems that moiré is reasonably well controlled given the absence of an AA filter. (image converted to JPEG from RAW)
http://flic.kr/p/auqdNt
I have used the 21/2.8, 25/2.8, 28/2.8, and 50/1.5 on the M-module. All of them work really well with minimal if any vignetting or corner colour. I particularly like the 50/1.5 Sonnar on the M-module as the rendering and bokeh are gorgeous, and TTL focusing means that focus shift at f1.5 is no longer an issue.
I have used the 21/4.5 with great results. My only gripe is that the adjustments you make (color shifting in the corners, vignetting, etc) are applied to the JPG only and not the DNG.
Love this brilliant little lens. Not the f-stop that ppl will bat an eyelid, but solid performer ... corner to corner resolution is one, and it's really really sharp!
Care to share what's your settings for the Color adjustments?
