pauld111
If you were on the look out for a Rolleiflex, which would be the best model, a 2.8 GX?
Thanks
Thanks
Thanks
IMO, finding one with clean glass in good operational condition should trump what is considered "best".
Rolleiflex : which is the best model ?
The BEST models are the PROPER Rolleis.
If you want a proper Rollei you need to buy a 3.5E thru to early 3.5F or 2.8C thru to early 2.8F - either Planar or Xenotar, preferably unmetered.
These models were made when Rollei were at the top of their game - genuine leather covering, half-moons fitted, usable with Rolleikin 35mm adapter.
Everything that came after the early 60s was increasingly inferior because Rollei started counting beans and economised on materials and machining.
The 2.8 GX and FX and the modern Teles and Wides are an overpriced pale shadow of a PROPER Rollei, their only advantages being a built-in meter ( good when it works, very expensive when it doesn't...) and slightly more contrasty lenses.
Why buy modern inferior quality models costing megabucks when so much better made earlier equipment is readily available much cheaper ?
Easy choice to make, seems to me...
Benjamin makes a lot of sense in post #5 above. What kind of look do you want and there are the model categories. I went through this last year, I like the 50's-60's look, and my first Rolleiflex was an inexpensive MX Automat, on the left below. I didn't even know if I liked using the camera so I bought a user and tried it out for a while. After finding out that I really liked it I started looking for an excellent condition E3 made in the early 60's (right).
I settled on an E3 because I really liked the way the Automat worked, it doesn't have a meter and the build quality is said to be very high. I also did a lot of research and used The Classic Rollei - A Definitive Guide by John Phillips which was extremely helpful in sorting out the myriad little differences between all the models. I strongly recommend Phillips' book; it was absolutely invaluable. The Automat models were made by Rollei from 1937 to 1976 and they were very popular; small, light, well made with excellent glass, they are also very easy to use.
The f2.8 models are a little bigger and heavier and I'm not sure the extra half stop makes that much practical difference. I tend to use my E3 with a tripod; a totally different kind of photography from using a Leica and that's the point for me. YMMV.
Me, too! (..........)NO, prefer late 2.8F
