ruby.monkey
Given the Fuji connection, perhaps the equivalent of a product-improved GS645/GS645W pairing?
Personally I'd like the equivalent of a GSW690 with a built-in spot/matrix meter and added aperture-priority autoexposure.
Zero image? Pinholes are lame, unless you do it on 8x10 sheet film and contact print that ****. Even then it's questionable.
6x12 is for old sweating men with old sweating hands who want to drag around big cameras to show off. Lots of options already available, AKA: GRAFLEX.
6x7 is OK if you're into that sort of stubby look. 6x9 shoots just like 35, easy peasy. Nobody has made anything portable in this size since 1960 (fuji 6x9 cameras are huge).
Most old 120 folders except the Makinas are worthless for enlargement: they were meant for contact printing. Hence the destruction of resolution by front cell focusing and lack of film flatness. Finding a 6x9 plate camera with a roll adapter is a solution out, but most lack rangefinders.
It seems a 6x9 with 65mm lens might satisfy most of us.
I just measured the size of a single exposure on the recently developed Velvia 100F roll from my Fujica GL690. It measures 56mm x 84mm.
Compared to 35mm format (24mm x 36mm), this 6x9 slide would be 2.3333 or 2.4 times the size.
If a new 6x9 rangefinder camera were to come out, it would either need interchangeable lenses, or has to come with at least two lens combinations: One to satisfy the 35mm equivalent focal length, and the other to satisfy the 50mm equivalent focal length.
In case of 6x9, 50mm equivalent = 120mm, and 35mm equivalent = 85mm (due to 1/2.4x crop factor).
Personally, I'd buy a 6x9 modern rangefinder by Voigtlander or Fuji that comes with any lens 70mm to 90mm in focal length. 🙂
6x12 and 6x17 are just too ... bizarre to my eyes.
