Brian Legge
To test the fixer hypothesis, you can try re-fixing one of your negative strips based on recommended times. If it becomes more transparent, that may be a significant part of your issues.
I believe he siad he uses water as a STOP BATH for 1 minute, not that he uses fixer for 1 minute.
As for the subsequent recommendation that he fix for 12 minutes with Rapid Fixer, that is excessive. 5 minutes is enough,
I think David's on to something there! Or you could take forty years to figure it out like I did.Hi,
What worries me about all this is that you've jumped in the deep end and will be struggling with a lot of things, all of them new and at the same time. Dare I suggest you try a slower but, imo, more pleasant film like FP4+ and get it D&P'd by a lab (and get them to scan it too).
Doing that will let you see what can be done and will eliminate the camera from the equation, although it may simply mean a slight change in the taking technique to make a major jump. A lot of us, f'instance, often use a certain camera and a certain film in one way only like (say) centre weighted and -½ stop.
As I see it every step you take follows the previous ones and taking the whole lot in one go and then trying to analyse what went wrong is very difficult. Best to arrange an easy start and build up a bit of confidence. Even things like loading the tank and pouring the yuk in and out can be critical, especially when you're new at it.
Regards, David
Iv scanned some photos that were developed professionally and they look great...
MUCH bettrer. I still think you are underexposing sometimes. In low light, try to err on the side of overexposure for better skin tones. Much better though!Alright folks so I developed a roll with everything else identical except fixing for 9 minutes. And I think I have found my problem! Checkout some of my photos on my flickr account and please let me know if these look better to you as well. I appreciate everyone's input! Thanks guys/girls.
What kind of fixer are you using? Ilford Rapid fixer? If so 9 mins. is still way to long. The plustek scanner scans up to 7200x7200 dpi.
Here is a tip: Cut off the leader of your roll of film & drop it in the fixer & time how long it takes to clear. Times that by 3 & use that time to fix your roll. IOW if it takes a minuet to clear the leader then 3 minuets should clear the film. Should never take more than 4 minuets. Don't forget you can reuse fixer.
