greyelm
Malcolm
GF1 + 45-200mm
Hows this? -------------All Bokeh
DSC01321a1 by yoyomaoz, on Flickr
A Canon 58mm f1.2 mounted on a Sony NEX 5.
Also, if your post uses a link to your picture located elsewhere, such as Flikr or PhotoBucket, and you later remove the photo from that source, that will break the link to the pic here, upsetting the flow of interaction for anyone looking back through the thread, with blank gaps where the pics once appeared.
I think the only solution is to avoid having the linked pic removed from the source. The break can happen inadvertently if the photo host deletes your pics or goes off-line.Doug, is there a remedy for this broken link problem?
