My Leica M6 rewind knob wont work
Mikey_Rotten
12:22 AM
Finland
Today happened during trip that my Leica M6 rewind knob somehow tightens so hard that I cant load the shutter because its too stiff and the film inside might snap.
This happens every 10-12th frame of the film.
Does anyone here ever had a same problem?
I had mine completely seize shortly after I noticed it getting really tight. It happened one day when I was on assignment, on a tight timeframe and stress out and I forced it and snapped something inside. Turns out I busted one of the forks inside. I bought a $15 replacement, opened it up and fixed it the following week. It's an incredibly easy fix if you have the clamps, spanner wrench and some micro drivers. Lucky I had all these as I do many of my own repairs.
ah the pitfalls of the change to the rewind design. yes I have heard of this too and experienced it once in my m4 before fixing it up.
Common problem and easily fixed. My M6 had the same problem. In my case it was the entire top plate that was slightly loose. There was movement by about half a mm. Thirty minutes in Leica Ginza and it was fixed.
Happened one time with my M7 when I loaded the film incorrectly, I kept rewinding it although it was very stiff, I thought I would snap the film rewind mech but I survived.. So far so good after I make sure to load properly and slowly since then.
