CafeConLeche
Hi, I am trying to fix this QL17-GIII, it has got few issues, including stuck shutter blade, corroded battery contact, meter issue, mold on lens, and bad light seal. I was able to fix most of them, except this finally issue. The shutter is locked in manual mode.
The shutter works fine in A-mode with battery when not over/under exposed. But in manual mode (with or without battery), the camera locks the shutter and won't let me fire. This is my first QL17-GIII, and I don't have a working one to compare with. At first I noticed the meter is not indicating the f-speed that I have dialed, so I thought the needle trap is not trapping correctly and cause the camera to think I am under exposed and locked the shutter. But then I read on the internet, the QL17-GIII meter is disabled under manual mode, meaning the meter won't even indicate the F-speed that you have dialed. So there must be a linkage somewhere to override the shutter lock while in manual mode. I opened up the front panel on the left side of the lens, trying to see if I can find that linkage, but I can't see any movement when adjusting from A-mode to manual. It would be a much bigger project (a one that I am not sure if I will be able to handle) if I am to further disassemble the camera.
If you are familiar with repairing QL17-GIII, could you kindly point out where should I be looking at?
