Issues with Minolta Scan Elite 5400
swmlon
12:05 AM
London, UK
I've recently borrowed a friends Minolta Scan Elite 5400 and for the past day I have been scanning negatives, mostly black and white, none of which have been good. I am using the latest version of Vuescan, on the preview and scan there are streaks going right across the whole frame (as shown in attachments). I don't know what is causing this issue, I have set up view scan in line with the example in the link below as changing with the settings does very little. Except for the Make Gray From box, when I set this to green the streaks are less pronounced but they're still there. Is this a hardware or software issue? I'm thinking the latter as my friend has no problems getting scans from the scanner.
http://125px.com/articles/photography/digital/vuescan/
Thanks
Hello, I sold my 5400 a while back and remember that it did a similar thing with vue scan.
I think from memory I removed vue scan and reloaded it and this fixed it.
I always got better results with the Minolta software, have you tried to use that?
Cheers Andrew.
I don't have the Minolta software, and as far as I've read, it can be used on Win7 64-bit.
I've have uninstalled and deleted the Vuescan folder on the C: drive a couple of times to no avail.
I haven't tried that.
If I don't get the lines, does that mean then the problem is with the negatives? I doubt that would be the issue as I've tried a lot of different negatives with the same results. But I'll try this.
If I do get the lines, then I assume it's likely to be a hardware issue?
What happens if you scan without there being a neg in the holder, do you get a plain white image or does this have streaks also?
Mine started doing that ever so slightly in the highlight areas and only when used with Vuescan. Normally don't use Vuescan as I use the Minolta software but was experimenting. Never did it before then and no os changes that I know of so no idea. Didnt bother reinstallation, I just left it and went back to my usual ways.
I have calibrated the scanner before I scanned each negative to see if this would have an impact, but it didn't, I would still get the streaks.
Thanks for the link Andrew, although I have tried this method half and dozen times to no avail.
... I've not seen anything like that on my 5400, which is the MkI version but two things spring to mind:
Firstly, I always scan in colour in tiff format regardless of the media type, why would one discard 2/3s of the data the scanner is capable of delivering? I'm always careful to mask the frame so there are no large clear areas at the edge to muck-up the exposure. With monochrome I check all sharpening, dust and grain removal is switched off.
Secondly, that pattern of lines looks very like some sort of harmonic, a bit like some AC interference on the DC power-supply, like a rectifier or capacitor that was becoming defective.
With some tricks the Minolate software will run under win 7 64 bit. I know because I do it.
unfortunate i can't exactly remember but it has to do with reverting to the Vuescan driver instead of the Minolta driver.
So, you install the Minolta driver and then in the settings you specify the Vuescan driver.
i got the solution in this group:
http://tech.groups.yahoo.com/group/multipro/
Same fix also works for the 5400 and the Multipro
I was thinking this might be the case regarding interference, but I don't know how to test this and how to fix this if this is an issue.
And I've tried using colour tiff and the results are even worse, more pronounced lines.
I had to get replacement neg holders for my Mk 1 5400 because the original holders used to catch and cause a blank spot, can you try the mounted slide holder and see if that makes a difference?
Andrew
I unfortunately don't have the slide holder to try this out.
