What is this inside this lens?
geebeewien
7:23 AM
A friend showed me a few of his old lenses, and when looking through one, an Summitar, I saw the following in the inside:
What is that? Is it fungus? Debris? I only saw lens fungus once before, and then it looked more like cobwebs, not those whiskers that I would have identified as cleaning marks if they were on the front of the lens.
What would you think?
Georg
That does not look like fungus to me. I've read about cases where soft coatings supposedly decayed in such a craquelée pattern, but the cases I have encountered personally so far proved to be cement failure.
There may be a bit of fungus but it looks more like the balsum cement is failing.. A cracking pattern usually indicates failure of the cement..
