Themckane
Thank you....
Mamiya produced a couple of versions of a device called a Paramender for their C series TLRs. Fitted between the tripod and the camera, the user focuses with it in the lowered position. Before making the shot the Paramender is used to raise the taking lens into the precise position occupied by the viewing lens during composition of the shot. Parallax and perspective problems are thus eliminated rather than compensated for.Johan, I have thought of the Close-up filter solution too, but they will not correct for parallax. The viewing piece (one part or two) on a Rolleinar has a prism which corrects for this to some degree. If you are doing tripod work there is a separate item which I forget the name of at the moment, which you can engage once focus is achieved to lift the camera body slightly to correct for the parallax. If you use this device then the much less expensive because they don't say Rollei on them close-up filters will work.
In the end, for close ups, I figured my Hasselblad is better suited and I got a Hoya close-up filter, in 67mm as I have a Bay 60 to 67mm adaptor ring, and a Bay 60 close-up filter is over twice as expensive as a 67mm, because it is of course associated with Hasselblad.
OK, thanks, I was not aware of the Rollei type; I will have a look in "The Rollei Way" to see if I can find out more about that one.I just saw on ebay a Minolta version for the Autocord, and I am relatively sure there is a Rollei Paramender too. That is the accessory I was thinking of.
Yashica Mat-124G | Rolleinar 2 | Neopan 400
