Richard G
Got it off by prising it up from the top level at one corner, with the screw driver. Totally disassembled it looks very very clean. That's disappointing.
So I tried this fix twice now and the problem's only gotten worse. Is three cleanings really the charm or could the switch just be bad??
I've ordered a couple of ALPS switches from Mouser and am willing to try installing one. Has anyone tried this method and is it a better, more permanent fix to this problem?
I'd like to keep using this camera for a long long time....
Hello everyone. After many months of hesitating I eventually got hold of an original black HEXAR AF in pristine condition. I load the camera with film and realise that the shutter is doing all sort of weird things, not being able to hold down focus but mostly being unresponsive when I press down to take the shot. If I press hard enough it sometimes works, but really it is best described as random. I dreaded having to face that possibility and unfortunately here I am with this problem.
First of all, does that sound like the problem you are all experiencing?
I am really not a fix it guy at all, as someone else also said, but at least he was successful. I messed up cameras and lenses in the past trying my hand at repairs, but none was worth as much as this Hexar and really, I only just bought it and feel very frustrated that the first thing I have to do is perform surgery on it...
Is it really something that anyone half-competent with his hands can do, or are you all at a "semi-pro" level of craftmanship?
Thanks in advance.
I've also caved and bought a black Hexar, the test roll looked fantastic, and any issues were user error.
The only issue I'm having is that when switching it on, the camera sometimes waits up to about 10 seconds and then wakes up.
This happens more if it's been off a little while, if it's been turned on and off, it powers up much faster. Has anyone else had this?
