Zeiss Sonnar ZM
swmlon
11:47 AM
London, UK
I am looking to buy the C-Sonnar soon (once a store actually has one in stock or one becomes available on this forum) but I have one (probably so obvious bordering on stupid) question regarding optimisation for this lens.
Can I assume that if it is optimised for f1.5 that it is optimised for the film cameras like the Ikon or M2/3/4/6/7/P and not for digital rangefinders like the RD1 and M8/9?
Thanks
Thanks
It shouldn't matter. The Sonnar is optimised for f/1.5 as early versions were not and experienced focus shift. Its due to the make up of the Sonnar design. All that has happened is the focus shift can be experienced a few stops down. Which bothers me not, as I shoot the Sonnar wide open, without exception.
Whether you shoot film or digital, it would make no difference to this issue, in so far as I can see.
Thanks
No - why would that be the assumption ? If it is optimised for f1.5 then it is optimised for f1.5, if for f2.8 then for f2.8 - anything else would be unsubstantiated internet forum rumour-mongering with intent. Most of the lenses now will come optimised for f1.5 - enjoy ... and if you can't enjoy that, at least all the Konica "KM" mount lenses won't focus properly on Leicas due to the differing flange differences ... and neither will the Leitz CL lenses due to the different Cam angle ... sheesh !!
Thanks
I have the old Sonnar (Opton) as well as the new C-Sonnar too (both in black and chrome).
All 50mm Sonnar designs, new or old, exhibit focus shift due to residual spherical aberrations; so does the Summilux 50 pre, Summilux 35 pre, Summilux 35 Asph. v.1, even the latest formula Summicron 50 (just a little bit; see my post related to Focus-Shift.)
The C-Sonnars used to come out of the factory optimized for f2.8, the later production was for f1.5. Assuming you would buy the later production, you would notice the focus shift at close distances moving to backward of the plane you focused @f1.5 as you stop down to say f4.. How much? Just about two inches. How to take care of it: If you shoot f1.5- f2 then don't mind.. if you shoot f2.8 or f4 then try to focus just couple of centimeters behind the point of your actual focus. Example: Shooting at f1.5 or f2; distance about 1m, focus on the eyes you will get the eyes sharp. Shooting at f2.8 or f4; distance again about 1m, focus on the ears you will get the eyes sharp. (Or focus on the eyes first and then move your head two inches backward before pressing the shutter.)
Anything beyond 2m of focus, do not mind, it will be within the DOF. Anything to be shot f5.6 or smaller at any distance then do not mind again.
These are for ANY M-mount, be it for film or digital. On the Liveview bodies like NEX, m43, etc., you see where you focus so it is no issue at all.
I have various 50mm Leica lenses and the C-Sonnar too. Sonnar is my favorite 50; using it on the M-bodies as well as on the Nex. It has a different signature than all other 50mm lenses I use.
I had a C-Sonnar chrome and I used it on a Zeiss, M3, M6, M7 and R-D1. I do not even know what focus shift is. It was a tremendous performer with all those rigs and I was an idiot to sell it.
Call Popphoto and talk to Tony. When I bought mine, there were some prone to shift and others (later) that were not. I never had a problem.
I have one. Before I got the M9 I did some tests and could not decide whether mine was optimised for 1.5 or 2.8. In the end I forgot about focus shift and just used it. I love this lens at all apertures. It is beautifully balanced, strong construction, great ergonomics.
Here is a link to my formal tests with the M9 confirming why just forgetting about focus shift worked for me with my copy of the lens.
http://photo.net/leica-rangefinders-forum/00aKSW
Many used ones are optimized for 2.8 (and some people will not know what it is optimized if they used it on mirrorless live view cameras). As much as people say this does not matter... it does for some folks because it is annoying. It shifts a lot on digital rangefinders. Film masks it a little better according to internet lore. 🙂
My favorite lens hands down for portraits of people and things. Draws beautifully on film and digital alike. The focus shift is easily learned and accommodated if necessary but as has been mentioned, shoot it wide open 100% of the time anyway
No, its optimised for 1.5 on all rangefinder cameras.
I have asked the question about "optimization" maybe two years ago and Zeiss told me, the very early lenses were optimized for f2.8, then they went to f1.5. They could not tell me serial numbers as they did not record anything.
Thanks for the feedback. Now I just need to be patient and wait for a used one optimised at 1.5 to pop up somewhere. The price new (if I can find one) is a little steep.
Once you get one optimized for f1.5, get an ND filter (or two) so you can shoot it at f1.5 all the time, even with 400 speed film .
That's what I did when I had mine, although my need for an ND filter (in sunny Southern California) may be different from yours (in the UK) 😎
I found a reputable dealer within the UK that has this lens in stock, but they tell me the lens is optimised for f2.8 as all the lens are, I'm a bit confused as I was under the assumption that later batch of lens was set for f1.5 and that if I want to get this done through Zeiss it would be an additional £60.
This smells iffy to me.
Focus shift is really a very minor issue. Most lens/camera combinations will probably produce larger inaccuracies. I prefer a lens optimized for 2.8 because wide open it will just very slightly front focus, which is easy to compensate for.
Mine was optimized to 2.8 when purchased but got Zeiss reoptimized to 1.5 with no cost. You can get it done like me if your is still under warrantee.
