jsrockit
Moderator
Mostly small APS-C cameras for me... but I generally don't do fast action.
...... I also don't imagine that any of the adapters for M lenses would satisfy me: since none of the associated cameras has been designed to use the M lenses natively, I strongly suspect that the adapters entail unacceptable compromises the way the lenses can be used.......
--- Mike
So would your statement above include the Ricoh GXR-M? Their module is specifically designed for M mount lenses.
I picked up the Ricoh GXR-M for no other reason than to use it with M lenses. With its manual screen focus, best done at a wide aperture, in some ways it’s like an old, pre auto diaphragm SLR. But, with magnified focusing through an external viewfinder that rotates to also allow waist level viewing, it works well as a street camera. With no AA filter and some good M glass the results are impressive. What amazed me was, even though the sensor has angled cells to handle the peripheral rays of the shorter focal length RF lenses, it still works well with the longer Leicaflex R lenses.
Do you have a favorite lens you liked to use on the GXR?
I assume from the phrasing of the question that this is digital only?
iPhone 4s & GRD III if that's the case, otherwise GR-1 or M4-P + CV 28.
I guess I've here-to-fore rejected the GXR-M, in large part because the viewfinder is an extra box sitting atop the body which seems a bit kludgy. But following your favorable description and Bill's positive comments, I took another look at Michael Reichmann's review of the GXR over at Luminous Landscape. Together you three are causing me to seriously reconsider the GXR-M. This could end up resulting in a costly experiment. (But not too costly, right?)
--- Mike
