ferider
Very nice Brian. That last shot has real "Nikkor glow"
My favorite 50.
Brian Legge
Thanks! I think my general purpose favorite is still the Yashinon 5cm 1.8 but this Nikkor is really interesting. Once I can predict what it will do at different apertures I'll probably like it even more.
A few more from the first roll:
http://www.flickr.com/photos/cannelbrae/7984745541
http://www.flickr.com/photos/cannelbrae/7988887047
http://www.flickr.com/photos/cannelbrae/7991038343
http://www.flickr.com/photos/cannelbrae/7984753710
ferider
The "glow" disappears at f1.7 or so, Brian. Then it becomes sharp and contrasty. Its close up performance is legendary. And, because a Sonnar, it has very little distortion.
Brian Legge
Ahh, good to know, I was trying to figure out exactly where that change happened.
malkmata
From my first test roll shot with my recently acquired Nikon S2 with Nikkor S-C 5cm f1.4 lens. Kodak BW400CN
15_17A by malikmata52, on Flickr
19_21A by malikmata52, on Flickr
Brian Legge
Wider open, with lots of sun hitting the lens:
https://www.flickr.com/photos/cannelbrae/8178147050
https://www.flickr.com/photos/cannelbrae/8173795074
ferider
Tasting Wines
Tasting Wines
(LTM NKT lens, TriX @ 400, Rodinal 1:100 stand)
Tasting Wines
Erik van Straten
Nikon S2, NIKKOR-S 1:1.4 f=5cm No.414866 @ f/1.4, Tmax400.
Erik.
Erik.
ferider
LTM/NKT version, Leica M6 + Velvia 50:
Erik van Straten
Nikon S2, NIKKOR-S.C 1:1:1.4 f=5cm Nippon Kogaku Japan No.361184, Tmax400.
Erik.
Erik.
menos
Truly beautiful landscape above !
Erik - this is a wonderful impression of a moment!
I love the composition with curtain and table + the interaction between flower in foreground and hand in door - all so simple elements in a photo but brought together nicely here, others, including myself, would have not even recognised.
Erik van Straten
Dirk, I am speechless because of your kind words. Thank you.
Erik.
Erik.
malkmata
jvan01
Does anyone have photos taken with the 5cm 1.4 (S-mount) on a Digital M? Curious about getting an Amedeo adapter to use with mine.
filmtwit
Desperate but not serious
This is Antony
M7 + 50mm f1.4 Nikkor-sc in ltm
Kodal tmax 3200 @1600
hamradio
Question: are there any significant differences between the LTM, S-mount, and F-mount versions of the Nikkor-S 50 1.4?
venchka
When I started this thread I didn't own my 50mm D.R. Summicron. Since acquiring the D.R. Summicron, I have neglected the Nikkor 50/1.4. My bad. I need to use the Nikkor more often.
As for the question above: In theory, the two rangefinder versions should be identical. However, the SLR (F mount) version is a different formula and has been through many versions. Only a visual comparison of photos could detect similarities and differences between the rangefinder and SLR lenses.
Wayne
ornate_wrasse
Moderator
M3, Nikkor SC 50mm f1.4 in LTM, Fujichrome Provia 100F
retina777
filmtwit
I've had both the LTM and S-mount. They are about 90% the same with the only difference being minimum focus. The LTM will technically focus down to 0.6 losing coupling at 0.7. The S-mount you see above in the Amodora mount will only focus down to 0.9 meters.
Wayne
