Batteries for Lynx 14E
raid
Dad Photographer
8:35 PM
Florida
This topic has been discussed before, and some people favor one option over the other in some old threads online.
Currently, what would you do if you were a user of a Lynx14E?
Use PX640A? 1.5V in place of 1.35V?
Use an adapter (on ebay for $7 or so) to adjust the voltage?
The best way to keep the small batteries in place is which?
Thanks.
Meter in mine doesn't work, so I just wing it, Raid. But what I did do before finding that out, was to use a battery of the proper voltage, and place a coil spring in the chamber to take up the slack. I don't remember what cell I used, but it did power up the circuit, as one indicator would light, but not the other.
PF
I could use small batteries and add some aluminum foil to fill the battery chamber. Or I use an external meter.
You'll love this one RAID....
I bought a couple of adaptors from a guy who was selling on eBay. When I got them they turned out to be the base of a .410 shotgun shell, with the shell casing (plastic) cut down to just within 1/8 inch of the copper base. A px28 battery just fit in the casing. There was a loose rivet peened over in the primer hole, and a spring providing tension on the rivet holding it against the battery. It hit the contact in the camera where it came through the primer hole. Worked like a charm.
I emailed him and said..."Hey, these look an awful lot like the base of a .410 shotgun shell?". He responded.... "YEP... pretty crafty huh?" I think the rim around the base was ground or filed down, but it was a perfect fit... in the camera, and for the battery.
Double HIT>>>> Pheasant under glass, and a battery adaptor for your lynx.
Now tnis is interesting!
Is this guy still making adapters?
There is someone who sells an adapter on ebay.
I may have been confused...
I think the adaptors I got were for the G series camera's
It looks like the lynx used 2 1.35 mercuries, so now the workaround is to use the PX640A (2) which come to 3 volts.
Here is a link with some discussion on the Lynx batteries:
http://www.flickr.com/groups/lynx/discuss/72157603738534421/
I also checked the Yashica-guy.com site. He has a lot of info on these camera's, and I thought he sold adaptors.
My best workaround for mercury 1.35 are MRB625 Wein Cells, which have a flat discharge curve but a shorter life span than the old mercury batteries. Then I also use the hearing aid 675 zinc airs, which are 1.4 volts with a wire ring or a plastic tube around them to make them fit. They are very inexpensive.
