Velvia 100F
colyn
ישו משיח
10:25 PM
CowTown, Texas
I have 6 rolls of Velvia 100F in the freezer that I will be shooting in the near future.
Checked out Freestyle and found their 1 pint kits to be reasonably priced so I'll be ordering on.
Haven't done slide film in years so this should be fun..
Any samples of this film??
I have used this film, I really rather like it too! I'm currently trying out Kodak E100VS, which seems quite nice! Less saturated though.
Anyway, samples.
Velvia 100F is an excellent film! Saturated, but nevertheless with neutral grey balance.
- Extremely fine grain, on the same level as the benchmark Provia 100F (which has even a bit finer grain than Kodak Ektar).
- Extremely high resolution: Lens manufacturer Carl Zeiss has tested this film in their scientific resolution test with 170 lp/mm at contrast of 1:32 (for comparison: the Nikon D800 reaches 90 lp/mm under the same test conditions);
at lower object contrast of 1:4 or 1:6 you still get resolution values in the 130-140 lp/mm range; for more details see the scientific tests here:
http://www.aphog.de/index.php?option=com_content&task=view&id=401&Itemid=1
- excellent sharpness.
The Velvia 100F has a bit more contrast compared to Provia 100F and Provia 400X.
Both Provias have a very natural, accurate and neutral color balance. They are not as color saturated as Velvia 100F, Velvia 100 and Velvia 50.
The best performance with slides you have with
- viewing them on a light table (with 5000 - 5500°K color temperature), with an excellent slide loupe. I can highly recommend the loupes from Schneider
http://www.schneider-kreuznach.com/foto_e/zubehoer_lupen.htm
and from Rodenstock
http://www.rodenstock-photo.com/en/main/products/magnifiers/aspherical-magnifiers/
With these loupes on a light table you will see them in their full resolution and color brillance.
- and of course viewing them in projection with a good slide projector on a screen. That is a league of its own. An absolutely unsurpassed performance. Simply stunning. The best presentation method for big enlargements (outstanding quality and lowest costs).
Jagwar.jim: The OP is asking about Velvia 100F. Your blog is about Velvia 100. These are two films, not quite the same. I think 100F has a fourth color layer, giving a somewhat different color rendition than 100. Some have expressed a preference for 100 over 100F, so it might be important to be clear about the difference. I think the 100 you used is more saturated than 100F. Just my impression . . .
Sorry you're totally right. I was using Velvia 100! Thanks for pointing that out 🙂
