Harry Lime
Practitioner
I think one of the biggest questions for street shooters is how well zone / scale focus is implemented. If it's poorly executed it will just be a PS, albeit with a huge sensor.
Rockwell kind of hammers it. (He's an editor's nightmare, but technically quite reliable.)
For example the shutter speed has a dedicated dial on the back...
I actually have an RX1 and it is superb. As a previous M9 owner the RX1 overcomes many of the problems with the Leica, and the best way to think of it is as a pocketable 5D with a top quality fast 35 lens on it.
I have used it professionally at two events in the last week where it was my second body (well, 4th actually as I had two remotes) and it turned in some beautiful images alongside my 1D IV bodies and L lenses.
Usability is great and some people simply havn't tried the camera and are talking nonsense. For example the shutter speed has a dedicated dial on the back, and setting the user memory settings took me 30 seconds. Menus are fine, way simpler than the OM-D, and the build quality is very ver solid.
If you are after a small full frame camera with a superb lens and cant afford an M and 35 cron then this is the one for you. If you are lucky enough to have a wodge of cash and can afford the Leica then thats great and I would have gone that route if I had the cash. If you can't afford the RX1 then you'll find the Olympus OM-D to be an admirable substitute (I have one of those as well).
Overall, a superb piece of kit.
Wondering what problems you had with the M9 that the RX1 overcomes. A used M9 or an RX1 would be my first two choices in a higher end digital camera. Would probably use the M9 with my 35mm Summicron most of the time so would love a comparison between the two.
Great to hear from someone who's actually used one.
