mhoskin
You can also use a 1.4 volt zinc/air battery (#675 for hearing aids) with a simple home-made adapter: http://rick_oleson.tripod.com/index-111.html[/QUOTE]
Thanks for the link. I just did this for my new-to-me M5 and it works like a charm. The readings agree with my handheld spot meter. If there's one small detriment to the 12AWG hack it is that the thickness of the wire rim exceeds the thickness of the original battery. This means the battery cap won't screw in quite as far as you'd like. If I had a lot of time on my hands I'd consider using 14AWG wire and after molding it around the battery would flatten it down some with a hammer. You certainly can't beat the price though.
-Mark
-Mark
