varjag said:Jon, from your infinity focus comparision I see that Voigltander isn't quite focused on infinity, but on the branch. Could it be collimation issue? It'd explain some of the difference in performance.
I thought the Voigtlander might not be adjusted to focus all the way to infinity, pulling up just short, but the test shots I took at closer distances match the infinity results fairly well. It might well be a design issue, or a collimation problem as you mentioned. The Voigtlander is really good across the frame when stopped down a bit, though.
