68degrees
Nikon FM wide angle. Whats the sharpest manual focus AI or AIS wide angle Nikkor for Nikon FM that you know of?
Probably the AIS 28/2.8, the one with the 0.2m close focus.
what do you think of the 20mm 3.5 AI?
I think that contemporary CV lenses would be sharper as many of the Nikon primes are not up to date from my recollection. Zeiss would probably be sharpest but $$$. However if you want sharp, going RF makes more sense, to me.
The Nikon 24/2.8 has been my benchmark SLR wide angle since 1976. I got my first one in 1976. I've updated a couple of times since then, my current version is the AF-D.
May be or may not be spectacular, but for me it is absolutely good enough.
I have the 24 and was wondering if there was a sharper one. Also during the course of this research I used a reverse ring to mount it to my FM and was amazed at the magnification. Does anyone know what it is? its got to be at least 2x lifesize.
Measure it. Focus on a mm ruler, see how many show up across the frame. Then divide that number into the size of the frame format, that will give you the magnification.
For instance, if you're shooting with a Nikon APS-C format DSLR, the long edge of the format is 24mm. If you can see only 20mm across the frame, divide 24 by 20 and you'll see that the magnification is 1.2:1 or 1.2x life size.
G
