Nikon Rangefinder Patch
Hogarth Ferguson
1:19 PM
I owned and loved my nikon s3, I even have it tattooed on my leg. The rangefinder patch was dim, and upon reading more, and having handled quite a few, I find them all dim. Is there a way, or service I can use, to make it brighter?
I really intend to buy another one soon, and I'm not too big of a fan of the SP or s2, the s3 really is the bread and butter, but I am hesitant because of the patch.
The thing that makes the *most* difference in bringing a faded Nikon rangefinder focus patch back to life is cleaning the diagonal surface of the half mirror prism. I've cleaned that surface on a Nikon SP and several Nikon S2s with faded focus patches, and after cleaning the focus patches went from almost unusable to almost or on par with a clean Nikon SP 2005.
It goes without saying that cleaning the front and side surfaces of the half mirror prism and the surfaces of the main prism will help, but that's only good for a 20% improvement. Cleaning the diagonal surface gives you the remaining 80% improvement. Below is a half mirror prism from a Nikon S2 rangefinder (removed from the camera for ease of cleaning). There is only a small gap between the prism and the metal casing so the trick is to slide some lens cleaning paper slightly dampened with lens cleaning fluid through that small gap. The Nikon pros at Kiitos Camera Repair in Tokyo use bamboo paper because its thin and rigid.
With the S3, you could also put a blue color filter (I used a B20 Fujifilm filter) on the main viewfinder window. It will make everything look blue through the finder, but the focus patch will stand out a lot more.
You don't need to take the rangefinder out of the camera to clean the diagonal surface of the half mirror prism. Instead, you can can access that diagonal surface by removing the front plate and small RF window, and then gently sliding dampened cleaning paper into/out of the above mentioned small gap. Repeating the cleaning six or so times should make a big difference. Just be careful not to get any damp lens cleaning paper stuck in there.
I can see good reasons for moving this to the repair forum, but is this not a case where it would be equally useful in its original place of the Nikon RF Forum?
I appreciate the remaining title in that forum is useful as a guide to why it is moved and is still accessible but if "cleaning" were added perhaps it would be more so?
Is there a good repair technician in the U.S. who can do this cleaning as part of a CLA? I recently purchased a Nikon S3 with the matching 50/1.4 lens. The camera and lens are very clean but exhibit the faded patch. I may sell it eventually, but first I'd like to shoot the camera and see how well I get on with it.
I thought this thread was fine in the Nikon RF forum too. I probably wouldn't have seen it and thus not replied if it was initially posted in the Repair / Camera Care forum. Hmmm...
That would have been a shame as your contribution is unlikely to be improved upon for the OP, and we all enjoy looking under the hood, especially when someone else is taking the risks.
https://www.davescamera.net
Daves Camera Repair. He is a trained Nikon Tech.
Thank you for the info. I have to say, having been on many forums in my life for many different hobbies and interests, this has to be the best and most informative reply I have ever gotten. Thanks so much.
Don't remove the half-mirror unit or it will be a mess to reinstall it properly afterwards and to get a vertically aligned rangefinder patch.
If you remove the camera top cover, the camera front cover and the small window in front of the half-mirror unit, you'll be able to slide a sheet of paper damped with Eclipse cleaning fluid between the diagonal surface of the half mirror prism and its metal surroundings.
Like Jon said, use some rigid paper - you don't want the damped paper to tear out and stay trapped between the half mirror surface and the metal casting... 😉
You'll need to repeat the operation several times before the half mirror diagonal surface gets clean enough. Then, the RF patch will be day and night if compared with what it was before indeed.
Glad to hear that 🙂
Thank you! I'll contact Dave.
Many repair guys don't realize that the diagonal surface of the half mirror prism can be cleaned, so I'd recommend checking with Dave that he knows to clean it.
True indeed. Its definitely best to leave the rangefinder mechanism in place.
Frustration with the weak focus patch is what led me to the Leica. I prefer the index-finger focusing of the Nikon RF but I never saw a Nikon RF with a real bright, contrasty patch. But then, I have not handled that many of them...
Many years later, the tip to clean the back of the prism still works perfectly. Tried it yesterday on an S4 with a barely visible focus patch, and the results are immediate and astounding. It’s easy, too - I am not in any way DIY-gifted, and this was a ten-minute job.
I received a new to me S4 yesterday and I believe it could use the cleaning you describe. I can probably figure it out without them but somewhere over the past 9 1/2 (!) years, your illustrating photos have gone astray. Is it possible to reattach them? @jonmanjiro
Thank you!
William
William, I wasn't able to find the photos I originally posted, but Richard Haw’s excellent website has all the info and photos you need. Specifically, see the link below.
The first photo in the Disassembly (Rangefinder Assembly) section shows the rangefinder prisms from the front. The prism you want to clean is the small one on the left.
The 10th photo in the Disassembly (Rangefinder Assembly) section shows the half mirror prism assembly removed from the camera.
The 1st photo in the Conclusion section further down shows the surface of the half mirror prism that you need to clean. To access it, you just need to remove the front plate of the camera (four screws) and the little glass window covering the half mirror prism (three screws). Once the glass window covering is off, you should be able to carefully slide in some cleaning paper to clean that diagonal surface.
