Can't open summarit 5cm 1,5
fathom
10:01 AM
Hi!
My lens has haze inside, so I need to open, and clean it.
I have checked every tutorial how it should be opened. But, mine won't open like that.
I did unscrew three screws and one from the focus ring. But the front part won't rotate. I tried to use force, still nothing.
Any ideas?
It is summarit f=5cm 1,5 nr 820136
One of these tutorials I used:
http://lensfix.blogspot.com.ee/2015/04/leica-summarit-50mm-f1.html?m=1
I resolved that problem. (Under silver ring are extra 3 screws, so options are to rotate that silver ring until you see them, or to push it down.) Problem solved and lens is clean!
I have the same problem, can't open the lens... And used same link with the tutorials with pin insertion and and removing 3 screws that hold the optical block. So where are the other 3 screws (Under silver ring) you've mentioned?
