Freakscene
Obscure member
How about now? Mmmmkay? 🙂
Yes, they are back. The Nereocystis photos are superb.
Marty
Copy thatYes, a group of very nice underwater photos! 🙂
But still, except for the Sekonic meter shots and the first jellyfish, none of the prior ones.
https://www.bhphotovideo.com/c/sear...9519Xd7ad039e5b240f879ee7e555f7eaedfc&DFF=d60
B&H has 70mm type II perfed HP5+ back in stock 🙂
Is the water filtered?
Do you pour all the water out periodically? I do
Also Hypo Clear step can be added if it is fixer
Are you using Photo-Flo?
I mix mine with distilled water for final step
It seems to me that the value of 70mm is the ability to take a large number of frames before reloading. If there is a need for that, maybe for aerial photo mapping, and little need for a variety of films, then there could be an economic reason as well. But you would have to accept the same development for a great many frames, and would be limited in film choice.
Browsing through the 28 pages of this thread, I saw a nice portrait; a landscape; a street shot; cars; underwater shots; and a snow scene. The other 95% of the photos were of film backs, film cans and boxes, developing reels, cameras and lenses. Gearhead stuff. Since I am a gearhead, I think that's fine; but am I right in thinking the satisfaction of 70mm for hobby purposes is in the gear, not the pictures?
For me I make 24 exposure rolls, and I have five or six kinds of film in the freezer. I have four A70 backs so there are plenty of choices. I've never used +1 and -1 backs although that's an interesting idea for me.
70mm is a challenge to get working and I enjoy the challenge. Lots of questions and interest about different ways to do this, so lots of postings about gear. This is a gearhead forum 🙂
If you have a Hasselblad you have probably seen those dirt cheap A70s around and wondered if there is a way to make them useable for photographing?
Ilford and Agfa make fresh 70mm film. Outdated film works very well so plenty of choices.
I've been using some SS pots to process the 70mm in. I've noticed some white grit here and there on the negs, which is most likely fixer.
I used some Kodak hypo clear for a roll and it helped a lot.I bought a box of laboratory filter paper to use a large funnel to filter my D76 derivitive ADOX Borax MQ. That eliminates all the little floaties for me
Maybe also filter your fixer?
Takes a while I can tell you but worth it
Hi Cal,UPDATE: I got the rare Linhof 645 CINE from Germany. Came with a pair of Linhof cassette bodies, but no spools.
I loaded and tested it. First off it seems the mask is not removable without taking off the Graftek flange which I will do later today at work, but the good news is that the shell will allow me to use the darkslide slot to make a removable mask. Also know that the 4x5 and circular 2x3 Graftek back plates both use ALL the same screw locations so they kinda are modular.
So in loading the 645 CINE the first thing that is noticed is the shorter throw of the film advance. I takes 5 strokes to advance to "1" on the film counter instead of only three strokes on a 6x7 CINE.
The next thing is I learned the frame counter alternates; one stroke will advance the counter; but the next stroke will skip advancing the counter; so it really takes two strokes to increase the counter by one increment. Know there is a second window that shows and indicates that the film is positively advancing.
The huge surprise is that I get 60 plus counts on the 645 CINE, meaning I get 120 plus 645 exposures on 15 feet of film.
The end game her is to have a common shell with the circular 2x3 Graftek backing plate and use a 645 mask using the darkslide slot that can easily be removed. I can then utilize a 6x7 CINE insert that comes from a 4x5 6x7 CINE without the mask for 6x7 format; but I can also use the 645 insert with mask in the same 2x3 Graftek shell.
Also know the added weight of a CINE counters an otherwise front heavy Linhof. This camera would be great to shoot the Gay Pride Parade, the Halloween Parade, or the Mermaid Parade.
Cal
