nintendo64lad
Any suggestions? Want a retro look.
Chris, do you have example images you could share using the ‘fogging’ technique with the Expodisc you described?The best way to get a retro look is to use old lenses, especially pre-WWII lenses since they are uncoated. Its not really possible to emulate that look using modern lenses, which render with quite high contrast. Even if you increase exposure and reduce developing time, the look with a modern lens still won't be the same.
Something you might try is a controlled fogging of the film. This involves exposing each frame twice (camera needs to be capable of multiple exposures to do this). Take the picture normally, with normal exposure. Then expose the frame a second time by covering the lens with a piece of white translucent plastic. An Expodisc works great for this. Set the exposure three or four stops under what the meter indicates (meter through the plastic...easiest if you use a camera with built in meter). Have the lens focused at infinity when you do this. The order you do this is not important; you can do the fogging exposure first if you want.
This technique works because uncoated lenses basically cause a slight veiling flare over the whole image, just like the slight fogging exposure does.
Simple solutions:
Find an old Summar
or a much cheaper option
Smear a little something on an old UV filter. Vaseline used to be good for this.
Experiment with digital to save film!
This is a long shot, but try a pre-war lens, plus Film Washi "Z". It is a near IR film, but if you do not use a 25A or stronger filter you can treat it as a hyper-panchromatic film, which was pretty common in the 30s and onwards. It says it is "moderate" contrast, but development could help that. It "light pipes", which occurs because it has no anti-halation layer, (see the data sheet) so you will get that general fogging effect that older films have.
It is pricey, and likely is not in reliable supply, so you would have to try it then buy emough for your needs while it is still available.
https://www.freestylephoto.biz/44603...Specialty-Film.
I have approx 5 rolls of the Washi Z in the fridge, waiting. The advice I’ve read is to disregard the first 4 or 5 frames, ie shoot blanks, due to the light piping during camera loading, but I won’t do that, just shoot as normal and if they’re duff so be it. I’ll have to read what’s recommended in terms of developer, dilution, times etc.
Maybe load it in a dark bag if you are comfortable doing that. Do you intend to shoot it as an IR film (i.r., 25A, IR72, etc.) or just as it is?
