Mystery 90mm Tele-Elmarit (-M sorta) ... what is it?
bjorke
Designated Driver
10:23 AM
Wine Country
I've had this lens for a while, it was a cheapish lens for a length I rarely use. It's fine for the job -- but I tried to register it on the Leica-camera site tonight and... it doesn't exist!
The serial number is in the right range for a 1973 "thin" - and while the focus ring matches a "thin" Tele-Emarit-M, this lens has a front bezel and DoF scale laid-out as a "Fat" Tele-Elmarit.
It's a perfectly usable optic, I like it for those occasional 90mm situations, but... what? Leica says there was no such lens with that number.
Feels... special.
That's what I've thought I have.... a Tele-Elmarit-M "thin" 90... and as time goes by I think I do have one, despite the differences between mine and what Ken Rockwell shows.
The "90" can't rub off, it's engraved. But this writer's review also shows his 1976 edition with the serial # on the front & a screw hole in place of the "90" -- just like mine. Oddities! Maybe the refactored engraving came later.
A double-check against Erwin Puts's big list shows my serial number is in the right range, so now I'm just stumped as to why Leica says there's no such beast (it does list the lens type, just not this serial number). If it was an expensive collectible lens, I could imagine it being forged... but a 1970's Elmarit?
It looks like the first batch of thin Tele-Elmarits. Yours produced in Canada. Like any first-run product, you can expect changes in the cosmetics in later batches.
One for example: Most Nikon F2 bodies have Plastic wind tips. The first 1600 used metal tips. I have two, Many other cosmetic differences of the first batch. These things happen, and 50 years later- changes were not documented and after 50 years, no one at the company knows about it.
https://www.l-camera-forum.com/leica...Tele-Elmarit-M
Edit- looked on Ebay, another lens in the same batch as yours looks identical. SO- consider yours as the First Run lens.
It looks just like my thin Tele-Elmarit, except that mine is slightly later in serial number, starting with 283, while yours start with 258. My Hove reference guide says the first thin TE was number 2,585,501, so yours is an early one indeed. Mine has no "90" engraving on the barrel, either. I think they started that later. Rest assured, your lens exists, whether Leica thinks so, or not!
Looks like mine - 2586072. There is no 90 on the barrel but 05 is engraved vertically to the right of the "Feet" marker. I have a box that says 11800 but has a drawing of the fat version. Very good performer BTW.
