Shab
m6
zeiss c-sonnar 50 1.5
fp4+
Like it a lot! Thanks for sharing!
m6
fp4+
Thank you, Mark. Just my usual HC-110h for 11 min. with light agitation. Pretty standard stuff.
John
Thanks Xabier I appreciate very much your work so its nice getting warm words from you.
Ophir
"Bye Daddy!" Donibane Lohizune [2017] - Leica M5 + VM 35mm 1.7 Ultron + Ilford DELTA3200 + Orange filter
Hi John, how many ml of HC110 do you put per 300ml? I use 6ml for 9 mins.
Hi Pan. I figure using a little more chemistry gives more tolerance for measuring error with this sticky stuff. So I use 7ml and 420 water for 1:60. HC-110 is so cheap I don't mind.
I use dilution H for a similar reason. I tried B a few times but everything seems more critical at 1:31 and five minutes.
With my 11 min. I agitate four gentle rotations on the minute. How about you? I like low contrast and particularly value the whites.
Maybe I'll try your formula. Dilution P(an) ? 😛 Your processing always looks good.
I'm a fairly recent returnee to film and am enjoying finding my way.
John
m6
fp4+
Neskowin by Jim Fischer, on Flickr
Neskowin by Jim Fischer, on FlickrLast weekend we experienced a wonderful 'February Fake-out' (a collection of unseasonably warm weather days in the middle of winter). It was in the upper 60's on the Oregon coast...a feat that it can barely match in the middle of summer.
All images: Taken at Neskowin Beach/Neskowin Ghost Forest. Zeiss Ikon ZM, Voigtlander 21mm f/1.8 Ultron VM, Eastman-5222, Rodinal 1:50
I'm surprised, Pan. Very fine grain. If the developer has stayed the same - it probably will - then the film has improved a lot. Very nice picture!
