Mudman
What did you customize on your m7?
This. So, I hope that this serial number has the updated VF and DX reader. Can anyone confirm? Cheers, OtL.
Good news: it’s here. Bad news: no batteries, so 1/60th and 1/125th only, lol. 5” of snow tomorrow, I still may try and get to the hardware store, lol.
Nice Royal QDL! Is this the Dreyfus-designed version?
Still waiting on batteries, but I went ahead and loaded a roll of HP-5. Should be able to grab batteries locally tomorrow, and I ordered a bunch on Amazon today.
You do know you can put in 4 S76 silver oxide batteries?
This is an a-la-cart camera, which had their own set of serial numbers. In this case, rather than relying on the serial number, take a look at the latch on the inside of the base plate. If it has a rubber washer under the center screw (unless upgraded by Leica, the early M7 cameras don't have this), you probably have the optical DX coding (if this is the case, it should also have the VF condenser).
