Canon LTM Does anyone use flash with a Canon P?
ColeCole
8:28 AM
I haven't found much info on how to hook up a flash/what's compatible. I'm guessing it's kind of useless because of the slow, 1/55th sync speed. but I'm curious to know if anyone out there utilizes it somehow.
Thoughts?
I've used flash on the Canon 7 and I can only assume it would work the same way on the P. As long as the flash you're using has a flash sync cable port it will connect to the camera. When you trigger the shutter the flash will fire. I won't go into detail about how to use a flash but in the best case you have flashes that works semi automatic with the aperture set.
Meh. The sync speed isn’t that important to performance. Exposure is entirely based on the light coming from the flash, which has to fire when the shutter pane is fully open. Faster sync speeds were achieved as manufacturers used vertical shutters and improved on curtain speed. This increased the ‘speed’ which has a fully open shutter pane, which you need for a standard flash to expose the entire frame. And then, there are some specialized flash units which use a long-duration flash, which can sync at any speed because it remains lit up for the entire period while the shutter slit travels across the frame.. but these are much more recent developments.
I do use flash -- including studio flashes -- on my P occasionally. Fjäll is right, all you need is a cable with a standard PC sync plug on one end (to plug into the camera's PC sync jack) and whatever type of connector your flash uses on the other end. If the flash also has a hot shoe, you may need to put a piece of tape in the camera shoe to keep it from shorting the flash contacts and making the flash go off spontaneously.
Another option if you have a hot-shoe flash is to buy a PC-to-hot-shoe adapter, which sits in your camera's "cold" shoe and has a hot shoe on top plus a short cable that plugs into the camera's PC connector. Then you just slip whatever kind of hot-shoe flash you want to use into the hot shoe on top of the adapter. It really spoils the clean appearance of your P, but it works.
Of course there's no TTL flash exposure, so you have to find a flash that has a "sensor eye" for automation (you set the camera to a specified f/stop and then the sensor eye controls the output of the flash to yield correct exposure over a range of distances.) Or, use a manual flash and the old-fashioned guide number method: look up the guide number for the flash at the ISO speed of the film you want to use (let's pick a guide number of 56 at ISO 100 as an example), then focus the camera on your subject, note the distance on the lens, then divide that distance into the guide number to get the f/stop you should use. In the case of our example, let's say your subject is 10 feet away; 56/10 = 5.6, so you'd set your lens to f/5.6. Warning: Sometimes guide numbers are stated in meters, so if that's the case use the subject distance in meters instead of feet.
If I'm going to go to the bother of using flash, though, I usually am going to want to use fancy flash -- two or three lights, modifiers, etc. I use Godox studio flashes with built-in radio power control, so all I need on the camera is a wireless transmitter to set power levels and fire the flashes. For my P and other "classic-era" cameras, I like to use this Flashpoint R2 single-pin transceiver, which is much more svelte than the big Godox TTL triggers, so it doesn't block access to the shutter speed dial the way they do. The transceiver connects to the camera's flash sync port via a PC-to-3.5mm cable. It makes a very handy setup on the P. Again, with no TTL flash metering, you're on your own for setting exposures, and if you're using several flashes the easiest way to do this is with a hand-held meter with flash metering capability.
If anybody is going to ask what's the point of using a Canon P with studio flashes, I will tell you why: because it's effin' awesome. The huge advantage of any rangefinder camera with studio flash is that you can watch your subject continuously through the viewfinder and actually SEE the flashes go off, something you can't do with any SLR. If you're trying to catch your subject's actions or facial expressions, being able to see the flashes helps you feel much more connected. Yes, even though the flashes are very brief, with practice you can learn to see whether you got the action/expression you wanted or not. And with the P (or with a Canon VI or a Voigtlander Bessa R3, all of which have 1:1 viewfinders) you can do that while keeping both eyes open, which is pretty much the ultimate in viewing comfort.
Finally about that 1/55 sec. X-sync speed: Yes, it's a bit limiting, but it's certainly not useless. If you're using flash in a dimly-lit scene or a studio setting, the flash usually will overpower the ambient light and 1/55 is fine. If you're trying to blend flash with ambient light, it makes your job a bit harder because 1/55 is the fastest you can go. BUT... even the fanciest modern cameras usually have flash sync up to only 1/250, and that's only 2 stops faster than what you get on the P, so it's not a case of impossible vs. possible but of slightly harder vs. slightly easier. If you're really into mixing ambient light and flash, you're probably going to have to juggle neutral-density filters a bit regardless, so you're not really incurring much of a disadvantage if you want to shoot with your P.
So, is that 'way more than everybody wants to know about using flash on a Canon P? You're welcome!
Wow, lots of good info. Thanks! Sounds like there are a lot of options.
I thought I might have been misunderstanding/overlooking something about sync speed but maybe not. I'd think that 1/55th is definitely too slow for handheld shooting. Is it not? Even still I can imagine having some fun with long exposures + manual flash.
1/55 is definitely not too slow for hand-held shooting, at least not with any lens you're likely to use on a Canon P. Most of us don't worry about hand-holding at 1/60 (with a wide or normal lens) and 1/55 is only microscopically slower.
Also, in dim indoor light, the flash is so much brighter than the ambient light that it overpowers it almost completely. In this case your effective “shutter speed” is determined by your flash's duration, which for small on-camera flashes typically ranges from about 1/500 to much, much faster.
In bright indoor light the situation gets much more interesting. If you're shooting with, say, ISO 400 film and an aperture of f/2, a lot of indoor lighting will be bright enough to to register with a 1/55 sec. exposure. If you combine that with some flash lighting, the result will either be a blurry mess or an exciting combination of flash-frozen and ambient-blurred exposures, an effect that's been popular in avant-garde photography for a long time but still is very much worth experimenting with — it's unpredictable enough that your flash-plus-blur photos are unlikely to look like anyone else's, and the technique relies so much on gut instinct that there's a lot of scope for creating a distinctive look.
This! I knew I was overlooking something. Really helpful.
that canon flashbulb rig looks very nice. I have a zillion bulbs. I'd have to go back to my old ways when I used them with a Crown Graphic.
