Minolta CLE -- how fast battery drain if left on 24/7?
ryca
@_2126000
5:25 AM
Western Australia
Love my CLE but that On/Off/SelfTimer switch absolutely scares me!! Seems like its something that will just give up in time with no warning Has anybody faced this? Was thinking to maybe just leave it on... thoughts?
I cant say for sure how likely that switch is to give out, but I have a CLE that has definitely seen a TON of use before I bought it. The metal plating is worn through in multiple places and the plastic body is showing through, and the switch in question still works totally fine. But, I also don't think leaving it on would be an issue, the meter is only active when your finger makes contact with the shutter button so I assume there wouldn't be a draw on the battery simply by leaving the switch to ON.
I've had mine for 8 years. the switch can be a little fiddly but it has never stopped working. I would not leave it on but I don't have any experience with that.
My guess is that switches like that can be fixed since electronic contacts tend to oxidize over time.
