boojum
Ignoble Miscreant
Good faith warning about the sky: we are a coastal community subject to onshore breezes and rapid weather changes. The look of the sky cannot be counted on as a constant. It is variable. Also the two posted images are JPG's which means that they have been through in-camera correction, in-camera correction in two different cameras. The two posted images are just "suggestions" while the DNG's are "fact."
Here are Google Drive links to the tests where the images can be viewed without needing to be downloaded. These are the images which are better used to evaluate the images and there possible differences. Thank you.
Again, the lens progression is 28mm, 35mm, 50mm, 85mm, lens opening f/2.8, f/5.6, f/f11. ISO 200, uncompressed DNG with no in-camera lens correction. I believe these are as raw a DNG as can be produced by the M9 and the M240.
Keep in mind that after each three shot group the lens had to be changed for the next three shot group with a new lens and so on for the four lenses. Then the first camera had to be removed from the tripod, replaced with the second camera, first lens attached and the three shots groups repeated for the four lenses. This takes time and the atmospherics will change slightly.
https://drive.google.com/drive/folde...vj?usp=sharing
https://drive.google.com/drive/folders/1OserqhHlhaySfAAWBU-SGpPNCmBQJbvj?usp=sharing
