Mos6502
Well, I had written quite a lot about these things, but the forum deleted the whole f'n deal when I added images.
So here's the basics. In 1956 if you only had $19 to spend on a 35mm camera, the Soligor 45 was it. It's about 2/3rds the size of a Leica IIIf, and looks like a Canon IV shrunk in the wash. Film loads through the bottom plate. Shutter speeds are 1/25-B-1/50-1/100, in that order. Why? Who knows, what did you expect for $19? Lens is a 4.5/40 triplet, may or may not be coated, hard to tell. The controls pick out f/11 and 10 feet in red paint. These settings make the camera a glorified point-n-shoot, but it's worth noting these put focus nowhere near the hyperfocal distance, even for a 40mm lens. The lens stops down to f/22, and jumps from there to f/11. Why isn't f/16 included? Guess you should have spent $20. Considering these cost barely more than half as much as an Argus C3 the performance is decent. It's a fun little cam to snap away on, although it keeps your hands busy. Shutter and film advance aren't interlocked. You have to push a button to advance each frame, and you have to remember to cock the shutter each time too! A later update of the camera features an interlock, but you still have to cock the shutter manually. Rewinding the film had me baffled. It took a few minutes to figure out that the advance button had to be pressed in and to the right, and the advance knob had to be pulled out. Why? $19.
Construction on 45 by Berang Berang, on Flickr
Jerk on 45 by Berang Berang, on Flickr
