Now, I'm the first to admit I'm far from a good printer. I don't do it enough, and when I do, I'm lazy as hell. I use VC RC papers exclusively (although only Satin finish - gloss is awful, IMO), only dodge and burn when I
really have to, and quite often rely on a printing meter to get a quick straight print purely to see what something looks like.
However, after Erik's last example of a split grade print, I'd like to present this print of a similar subject that I made last week:
This was literally just a case of slapping a +4 filter in the carrier (prints from XP2 tend to be quite flat), doing a test strip, and doing a straight print at that. Job done.
Is it the best print ever? No. If it was for exhibition or giving to someone else, I'd have put a lot more care into it. But it's got life, depth, and a rich range of tonal values - far more than the presented example of split grade printing. Also, the white sky does have the
smallest hint of tonality in the print that hasn't transferred well to the scan; if I was to print it again (which I probably should), I'd probably pre-flash the paper a tiny bit, as I tend to find that gives better results for me than split grade printing does.
Ultimately it's all subjective, but I've always been happier with the prints I've made with single exposures and a touch of dodging, burning and occasional pre-flashing than anything Erik's presented as an example of the wonderful, perfect technique that is split-grade. Your milage may vary, I guess.
