D
Deleted member 82967
Guest
Tone-mapping on the way from Color to Monochrome.
There are many, many ways to convert color to mono. There are also several fancy ways to map tones from one color rendition to another. However, I find that going straight from color to mono with a simple luminance RGB-to-Y' can result in quite a bland image for my taste.
A while ago, I got the GIMP and discovered fancy tone-mapping in various forms - one of which (Mantiuk 2006) jazzes up a bland color image considerably - enough to where a simple luminance RGB-to-Y'is more than adequate.
A sequence applied to a DP2 Merrill low-res street image:
Each step above is at option default settings. Hopefully it is obvious which is which! Bottom Right is Bottom Left with a bit of USM applied.
Not saying this method is best; it is only posted for interest.
What's your method?
What's your method?
