dourbalistar
Buy more film
Photo Warehouse in Southern California appears to have spooled down Double-X in stock, and they list 36-exposure single roll, 36-exposure 5-pack, and 100-foot options:
www.ultrafineonline.com
B&H also seems to sell Film Photography Project's X2 Eastman Double-X, but at a rather shocking premium of $10.99 for a 24-exposure roll:
www.bhphotovideo.com
Kodak 5222 Double-X Black & White Film 35mm ISO 250 - Kodak Black & White Films
Kodak EASTMAN DOUBLE-X Negative Film 5222 is an ISO 250 motion picture black-and-white film known for it's subtleties in tone scale and designed for general production use outdoors and in the studio, in dim light, and anywhere you need greater depth of field without increased illumination.
Film Photography Project X2 Eastman Double-X Black and White Negative Film (35mm Roll Film, 24 Exposures)
Buy Film Photography Project X2 Eastman Double-X Black and White Negative Film (35mm Roll Film, 24 Exposures) featuring Panchromatic B&W Negative Film, Motion Picture Film, ISO 200/24° in Standard Process, Subtle Tone Scale. Review Film Photography Project Eastman Double-X
wlewisiii
Just another hotel clerk
Well, the local camera store/lab had a roll in stock for 9.99 today so I decided to grab it. I'll have to see what I think running it through the N90S at box speed.
lohrentz
I'm on my second 100' roll of photowarehouse re-spooled 5222. It is cheaper than Ilford and Kodak conventional 35mm film in 100', and it works really well, comparable in quality to traditional grain films from these two vendors in my opinion. I usually shoot at EI 400 or EI 600, and develop in D76 or D96.Photo Warehouse in Southern California appears to have spooled down Double-X in stock, and they list 36-exposure single roll, 36-exposure 5-pack, and 100-foot options:
Kodak EASTMAN DOUBLE-X Negative Film 5222 is an ISO 250 motion picture black-and-white film known for it's subtleties in tone scale and designed for general production use outdoors and in the studio, in dim light, and anywhere you need greater depth of field without increased illumination.www.ultrafineonline.com
Buy Film Photography Project X2 Eastman Double-X Black and White Negative Film (35mm Roll Film, 24 Exposures) featuring Panchromatic B&W Negative Film, Motion Picture Film, ISO 200/24° in Standard Process, Subtle Tone Scale. Review Film Photography Project Eastman Double-Xwww.bhphotovideo.com
qqphotos
I've been playing with Double-X 5222, for no real reason other than boredom. I kind of like it. I've tried it in HC110, PMK, Rodinal 1+50, and pyro-triethanolamine. My favorite thus far is PMK 1+1+100 (14min 20C) which gives thin looking negatives with significant staining that nevertheless retain good shadow detail and have the unusual characteristic of needing basically no adjustments at all with my scanning workflow. Rodinal 1+50 gave objectionably excessive grain, HC110 was perfectly acceptable but with dense highlights that needed tweaking after scanning, the pyro-trieth was totally fine like it is with every film I've tried, and develops quickly. Mind you all this is from experimenting with only 6 or 7 rolls of film so it's far from scientific. But I'll probably keep a bulk roll around in the freezer for when I feel like it.
handrail shadow by eric volpe, on Flickr
tree shadow on wall by eric volpe, on Flickr
titrisol
Bottom Feeder
Freakscene
Obscure member
What speed / e.i. do you use for XX in PMK?I've been playing with Double-X 5222, for no real reason other than boredom. I kind of like it. I've tried it in HC110, PMK, Rodinal 1+50, and pyro-triethanolamine. My favorite thus far is PMK 1+1+100 (14min 20C) which gives thin looking negatives with significant staining that nevertheless retain good shadow detail and have the unusual characteristic of needing basically no adjustments at all with my scanning workflow. Rodinal 1+50 gave objectionably excessive grain, HC110 was perfectly acceptable but with dense highlights that needed tweaking after scanning, the pyro-trieth was totally fine like it is with every film I've tried, and develops quickly. Mind you all this is from experimenting with only 6 or 7 rolls of film so it's far from scientific. But I'll probably keep a bulk roll around in the freezer for when I feel like it.
qqphotos
