Pál_K
Cameras. I has it.
These photos are amazing. It is true: nothing looks like this. This process yields a color image which is somehow more enriched than one would get with any color emulsion. It is hard to explain, yet it can be seen.
I am going to try this - but it will have to wait until mid-Spring because right now everything here colorless and I have no pretty flowers inside.
dourbalistar
Buy more film
Thank you, Pál_K! The process certainly yields colors that are different than other "conventional" color film. If you already have all the necessary filters, you don't need to wait until spring. Just give it a try with some colorful objects around the house! I think the process lends well to tabletop still life, since you're locked down on a tripod anyway. Would love to see your results!
dourbalistar
Buy more film
Epiphyllum oxypetalum. Normally, the flower blooms at night (sometimes only once a year) and wilts by morning, but this one endured long enough for me to take a few daylight photos. Since I mainly use B&W, I took full advantage to make a trichrome color image.
Nikon FM2n, AI Nikkor 50mm f/1.8S, Kentmere Pan 400, developed in LegacyPro L110 at 1:31 for 5.5 minutes. Three individual black and white frames shot through Tiffen #25 Red, #58 Green, and #47 Blue filters, respectively, then combined using GIMP to create a trichrome color image.
2021.09.06 Roll #290-06589-positive-trichrome.jpg by dourbalistar, on Flickr
olakiril
2021.05.15 Roll #276-06160-positive-trichrome.jpg by dourbalistar, on Flickr
This is excellent.
Great colors in general in your photos, especially with the flowers...
dourbalistar
Buy more film
This is excellent.
olakiril, thank you for the kind words!
dourbalistar
Buy more film
Nikon FM2n, AI Nikkor 50mm f/1.8S, Kentmere Pan 400, developed in LegacyPro L110 at 1:31 for 5.5 minutes. Three individual black and white frames shot through Tiffen 25 Red, 58 Green, and 47 Blue filters, respectively, then combined using GIMP to create a trichrome color image.
2022.01.01 Roll #298-06946-positive-trichrome.jpg by dourbalistar, on Flickr
largedrink
Down Under
Great photos. The "combined using GIMP" step, how do you combine the 3 separate images?
dourbalistar
Buy more film
Thank you, largedrink! To combine the images in GIMP, I followed the instructions in this article:
http://archive.brhfl.com/ph.brhfl.com/2012/09/07/gimp-trichromes/
There might be some slight differences with the more recent versions of GIMP, but the basic steps should be the same. I'm using GIMP version 2.10.14 and export the combined image back into Lightroom for final edits. Hope that helps!
dourbalistar
Buy more film
2022.02.17 Roll #299-06987-positive-trichrome.jpg by dourbalistar, on Flickr
Dralowid
Michael
I'm old enough to remember doing colour seps in camera for repro (cheap studio advertising stuff). Registration was everything!
santino
FSU gear head
Really impressive still lifes. The colors are so unique. Have you ever tried to take three digital b&w pictures with appropiate filters and then merge in gimp? Probably not so much fun but should work too. I may give it a try (digital first, filmy may follow).
dourbalistar
Buy more film
Thank you, @santino, much appreciated! I have not tried it with digital, but I think the process is similar. Trichromy, especially with film, can yield some unique and sometimes unpredictable results. All part of the fun!Really impressive still lifes. The colors are so unique. Have you ever tried to take three digital b&w pictures with appropiate filters and then merge in gimp? Probably not so much fun but should work too. I may give it a try (digital first, filmy may follow).
dourbalistar
Buy more film
2022.04.18 Roll #304-07085-positive-trichrome.jpg by dourbalistar, on Flickr
Pál_K
Cameras. I has it.
Colors in the center of the photo reveal movement of suspicious creatures on the path and at the arch.
Freakscene
Obscure member
I say this every time you post these, but this is the nicest colour photography I look at. Really amazing. Thank you for posting them.
I’m planning to order some filters for my Monochrom for things that don’t move.
dourbalistar
Buy more film
@Freakscene, thank you, humbled to receive such a compliment. It would be interesting to see trichromy from a Monochrom. I assume the sensor would have a "fixed" spectral sensitivity, unlike film which would vary depending on the stock/emulsion you're using?I say this every time you post these, but this is the nicest colour photography I look at. Really amazing. Thank you for posting them.
Freakscene
Obscure member
Yes, the spectral sensitivity is largely an output of the sensor. The layers over the sensor modify it somewhat but you can’t swap that out either, so it’s fixed for the camera. Certainly there would not be differences as large as you see between films, although I’ve not compared the Leica and Pentax monochrome cameras for spectral sensitivity. Stick at it, they are so nice to see.@Freakscene, thank you, humbled to receive such a compliment. It would be interesting to see trichromy from a Monochrom. I assume the sensor would have a "fixed" spectral sensitivity, unlike film which would vary depending on the stock/emulsion you're using?
dourbalistar
Buy more film
Arches National Park, Fiery Furnace Overlook.
2022.04.18 Roll #304-07091-positive-trichrome.jpg by dourbalistar, on Flickr
dourbalistar
Buy more film
2023.04.09 Roll #327-07991-positive-trichrome.jpg by dourbalistar, on Flickr
dourbalistar
Buy more film
2023.04.13 Roll #330-08037-positive-trichrome.jpg by dourbalistar, on Flickr
