Godfrey
somewhat colored
I guess I maybe could or should have been more clear here: I was asking about the "overall look" including (but not limited to) the colour response.
I suppose, with digital, and with sufficient work and skull sweat, you could simulate more-or-less anything (at least to a point, and to some level of precision). I'm more interested in (if I can) just changing lenses to change the 'look' rather than shooting with whatever comes to hand then trying to simulate what I'm after in digital post-processing. In this particular case I was merely wondering "is there any Leica RF lens out there that, to some degree or other, renders things the way the Planar 45mm/f2 renders things for film?" For film, I guess, but I'm thinking more for digital. If I'm using film anyway, then I might as well just use my G2.
Perhaps there isn't. If not, then I need to think on what (if anything) I might do about that.
...Mike
Hmm. Digital ... "sufficient work and skull sweat" ..?? You use a profile creator and a reference chart ONCE to create a camera calibration profile that matches the color output you want, that suits your desires, and then you're done. I pick lenses on their non-changeable attributes; with digital capture, what the colors look like is always a matter of the body's calibration and profiling.
I owned a Contax G2 system, switched to it from my Leica M in the late '90s, and had the 28, 45, 90 mm lenses. It didn't work the way I liked ... I used it for a year and a half, trying to do what I did so easily with my M and take advantage of its autofocus. Didn't work. I sold the whole kit and replaced it with another M, brought me back to normal. The Contax's Zeiss lenses were good, but they didn't do anything particularly special to my eye that was worth the cost of converting them to M-mount (a one-way trip).
No disparagement to you intended. If you see something special in the Contax G and Planar 45 that you like, well, keep using them. Trying to get something else to do exactly that without having to put any effort into it is likely not going to work.
G
