wrs1145
A native Texan living far from home.
What do you recommend?
??It is designed to be primarily an incident meter, although I believe that was some attachment for reflected metering as well.
Sorry, I was thinking about the L-358.??
Built-in opal hemisphere slides in/out at the push of a finger for incident or reflected metering.
"... most reliable, easiest to use, hand-held light meter ... "What do you recommend?
I thoroughly agree! I own a Luna Pro Digital F, primarily used as an incident meter (and highly recommended for ease and accuracy!), and a Minolta Spotmeter F. I'll bring whichever one seems most appropriate for the situations I anticipate, and often, both. Medium format color transparency film is expensive and unforgiving!A different slant on the original question: Any incident-light meter will be both the most accurate and easiest to use, IF it's always conveniently possible to hold the meter in the same light that's falling on the subject. If you can do this, an incident meter will completely eliminate the need to adjust your meter readings to compensate for the brightness/darkness of the subject. It will quickly give you a reading you can pretty much use as-is, unless you want to tweak your settings to add a little more detail to a very dark or very light subject.
If you can't always put the meter in the same light as the subject, the most accurate and easiest way to get an exposure (IMO) is to use a spot meter to measure the most important highlight area and the most important shadow area, then average those readings.
So for the sake of convenience, you'll want to look for a meter that combines incident and spot reading capabilities. Minolta used to make one, the Flash Meter VI, which was so good that after Minolta got out of the meter business, Kenko bought the rights to make it; good luck finding a clean-and-working Minolta version now, though, and the Kenko version's availability seems to have become spotty. That leaves you looking at several current high-end Sekonic meters such as the L-858; sadly, these are expensive and much bulkier than the Minolta/Kenko meter, but at least you can hit up your favorite retailer today and buy a new one with a warranty...
