Calzone
Gear Whore #1
- Local time
- 10:46 AM
- Joined
- Nov 11, 2008
- Messages
- 16,873
- Location
- The Gateway To The Hudson Highlands
I’m more stiff than sore today after a longer than 4 1/2 hour hike in the woods. About 25 minutes of that hike in the beginning was more of a jog.
Still did a set of 8 pull-ups today already. Later today I’ll fit in a set of max pushups, and then a “Maggie” hike which will be shorter and less strenuous.
At my age pretty much I have to just do what I can almost every day or the long fade will settle into the long slow decline. Seems like the incline is also slow. Lots of beauty sleep needed/required. Pretty much if I were not retired I could not do this fitness routine. It ends up requiring a big commitment, is a lifestyle, and pretty much burns a lot of my time. Pretty much after dinner all I can do is relax.
I’m comparing a tricked out Rock Shox Judy XC that is fresh and was overhauled against the newer Rock Shox SID “Race.” There is about a 3/4 pound difference in weight, and the SID weighs in at 3 pounds with a 9 1/2 inch steerer I will likely have to trim.
I’m cool that the SID has the early 28mm legs because I’m basically a lightweight and strength and stiffness of 32mm legs of later SID’s would be just overkill. I’d rather have the weight reduction.
The Ti IBIS really is not really a Mountain Trials even though it features a 26 inch front wheel, and a rear 24 inch wheel. The wheelbase is 40 inches instead of the shorter 39 1/2 inches of my steel Mountain trials, the dropouts also are not horizontal either like on the steel IBIS Mountain Trials, and also the frame sizes when measured bottom bracket to top tube differ. Close but no cigar as they say.
But my Ti prototype fits into the period of IBIS history when the Ti Mojo was one of the hottest bikes being built that pretty much achieved the pinnacle of titanium bikes with internally butted titanium tubing. Pretty much legendary.
Pretty much the forensics are that the front triangle is just a 17 inch Ti Mojo, but the rear triangle was made smaller and shorter for a 24 inch wheel. The result is a short wheelbase that has faster steering and accelerates and climbs faster due to less rotating mass.
The IBIS SS I kinda bought by mistake due to bad advertising is a pre-suspension bike: a full rigid. The bike was advertised as a small frame, but in fact it was perfectly my size. Oh-well. In the later 90’s suspension forks took hold and bike geometries evolved and changed. The Mojo and Ti Mojo are bike designs built for suspension forks, as well as the IBIS Alibi.
Interesting to note that the Mojo and the Alibi geometry are the same. Hmmm… Sloping top tubes and the same angles.
There is a closed gravel road that bisects Blue Mountain Preserve. Earlier in the year I was bombing on this road on a descent and pretty much almost got taken out in a section that was full of gullies that was washed our. I came around a blind curve and luckily scrubbed off the speed to stay in control, otherwise a pretty bad crash involving gravel cuts.
I kinda have a nice linking trail to this gravel road which has a bit of climbing and is pretty long. Now I see and envision making the IBIS Alibi into a front suspension single or 2x1 to do interval and wind sprint training for strength. The gravel road is long, has rolling hills, and pretty much would be ideal for strength training and speed.
I have an odd combination of a 110 BCD Middleburn spyder and a NOS Middleburn 52 tooth chainring for converting the Ti IBIS into a 1x11 XTR fitness bike for the Empire State Trailway. I checked for chainstay clearance and I can exploit the modular design of Middleburn cranks by simply changing spyders with kitted chainrings for: a 63.59 single speed; a 1x11 XTR fitness bike; or a 2x11 mountain bike.
The front forks are also kitted out for easy convertibility, fitted with brakes and brake levers for EZ-PZ conversion.
Then add in the having three different wheel sets for having everything modular and kitted out.
The steel IBIS will get its cassette built wheels Can-IBB-Bill-ized for Ti IBIS use and can be built out as either a full rigid trials bike, or into an off road single speed, with or without a suspension (Rock Shox Judy SL). Would make a really cool DJ (Dirt Jump) or pump track bike with the suspension fork.
On the steel IBIS I have enough wheel sets built for single speed that the wheels can be kitted for both trials, single speed, or pump track. A second modular bike…
Anyways, some maniac thinking and excitement has occurred over the last two days…
Parts are coming in. Living the dream. I have two training loops figured out and I’m sure I’ll have many more. Beauty is that pretty much I have these trails so close to the Baby-Victorian. As for trials practice there are mucho rock gardens to learn how to clean, and I’m sure my bike handling skills will evolve greatly.
Pretty sure I will be known as the old man who rides the retro old school bikes at Blue Mountain. AJ already has me pegged.
Cal
Cal
