snaefell
This is a cool idea. If you use the cameras in landscape orientation, the image should be even wider.What I was hoping for with this setup was to get basically a digital version of a Panon Widelux/HorizonT camera. After some more test shots this morning I'm pretty sure I have that. The FOV is basically what you see ahead of you. On a couple of shots I have minor blend errors so I might see about redesigning the mount plate to get the cameras a little closer to each other to see if that fixes it. If not, I will reduce the angle between them slightly.
Do you plan to share the construction plans?
