What film developer is your favorite and why ?
John Bragg
10:36 AM
Cornwall, U.K.
For the longest time, I used only Tri-X developed in HC-110 H and that was my thing, like many others. The problem was that Tri-X became stupidly expensive, so I shifted to Ilford HP5+, after a brief fling with Delta 400. I now use Ilfosol 3 to develop my HP5+, after the change in formula of HC-110 and its subsequent disappearance. I find it to be the best developer for me personally, since I rarely rate the film at more than ei200 and it produces images that I can't beat with other developers.
Anchors at Charlestown, Cornwall by E.J. Bragg, on Flickr
Barnacles by E.J. Bragg, on Flickr
The real Rodinal. It had a super long shelf life, was corner sharpening, had good tonality and it increased grain (which I like). Current R09 developer is different.
For many years I used PMK, the last 10 years or so, Pyrocat HD. I appreciate the way staining developers separate the highlights.
I'm still using HC-110 ... it takes me an eon to use up a bottle of HC-110 concentrate, I think I've been using this one since 2006. I find it does the job nicely with most any film I've used. Might try using something else when I finally finish up this bottle... 🙂
G
G
That's my experience too. I opened a bottle in 2011 and still using it. When it runs out I might give DD-X a try.
Until the early 00s Edwal FG7
Now Rodinal (for anything below 100) due to the lovely tonality and control with dilutions/agitation
and DDX/Microphen for faster films, small grain and full tonality with the option of pushing
HC-110 with a bottle from around 2010. I process everything one shot at 100:1 stand for 60 minutes with 4 inversions at the start and again at the 30 minute mark. Works great with all the films I tend to shoot (Foma 100, 200, Kentmere 400, TMAX 100/400) and lets me process it all together.
Fomapan 100
I do similarly ... but different concentration and timings. HC-110 @ 1:49 @ room temperature (70-75°F) @ 8 minutes (5 sec 'tipping' at start, 1 'tip' every 30 sec thereafter). The biggest exception is Ferrania P30, cut the rating to ISO 40, and go to 1:99 concentration, process for 16 minutes. Seems to work for me. 🙂
G
Adox Rodinal is a favorite for some films; HP5 and Fomapan 100 look great with it. I started using TMAX (developer) when I found that Rodinal doesn't work well with Kentmere 400 and now it's also a favorite. Haven't tried any version of HC110 though, and I know that many swear by it.
Agree with this: T-Max 100 and 400 look awesome in Rodinal.
I switched to Xtol. I like the results - for my workflow. I presume that it’s slightly kinder to the world, as well. Plus, if I want to push film (which I rarely do), it can do a good job with that.
I'm using D-76 right now, but I've bought two 1-liter packages of ID-11 recently that I'll use once the D-76 is gone. I shoot mostly TMax 100 & 400 and Delta 400. However, I've been hearing good things about Xtol though. I wonder if there's a vendor of that stuff nearby (Kingston, Canada)..
..Avery
D-23.
Two ingredients that are very easy to mix so I always have fresh developer.
Works great with every film I currently use with the possible exception of Adox CMS 20 II. And it may work with that film as well but I just haven't tried it.
Easy to adjust its' working character through dilution, temperature and agitation, or any combination of those.
Seems to work very predictably whether I'm using a tray, doing inversion or rotation development.
I am sure there are others that have similar working properties but this is the one I have settled on for most of my work.
I am also working with Caffenol since the ingredients are very easy to acquire and mix but so far I have not learned it as well.
HC-110 here, too, mainly for its cost and shelf life. Always with HP5+. I like D-76 a little more and use DD-X for occasional pushing, but usually end up throwing out much of both because they expire before I use them all. They make me appreciate HC-110’s workhorse quality.
John
D-23.
Sounds great. Is it very much like Perceptol, but wirhout the sodium chloride ?
Am I allowed to say e6 with Ektachrome? 😉
Absolutely. Which E6 developer is your favorite. I picked up some Cinestill the other day but I have never used it before. The last time I used the Arista E6 1 Quart Kit and it worked pretty well. I think the Cinestill kit is a little different.
