Screw-in to the front of the Elmar, lock the lens at infinity, ensure the distance to subject is correct for the close-up filter, shoot. Apparently there was once a table that allowed you to translate various working distances to the lens' focusing scale, but without that table, this is going to be your best bet.How do you use it?
According to the guide I linked to earlier (https://www.cameramanuals.org/leica_pdf/leica_leitz_accessories_3.pdf), they were actually sold separately from the legs - at least in the US - with the code ELPIK for the No. 2 version. It also gives the following information for the No. 2 close-up lens: For distances from 21 9/16” to 15 15/16”, for objects of sizes 8 7/16” x 12 5/8” to 5 5/8” x 8 1/2”.Yes, I looked at this and thought that it was indeed part of one of the kits involving legs of different length to match different close up lenses. Maybe three sets of legs, a clamping ring and three lenses in a nice red box.
Not BEHOO but maybe BEVOR, BEOOY??
Edit: Here we go, No2 lens with BEVOR legs. Set camera lens to 1m use upper index mark on BEVOR legs and picture area is 14 x 21cm.
An asterisk denoted a duplicate serial number. No idea what it could possibly mean on this close-up lens - Jo Geier has the ‘3’ version of this closeup lens for sale and it too has an asterisk....and...didn't they use an asterisk on some of the prototype Summitar or Summicron lenses?
Maybe?
I don't think so, because the filter in question "reduces [the object being photographed] from 8.9 to 6.0 times", and the 1* and 3* filters similarly don't match a "1x" or "3x" reproduction ratio.2* is likely 2x. Used in mathematics, in formulae.
Early Elmars had a fine filter thread, which was more coarse in later Elmars, after about camera SN 9500. The close up lenses for the later ones should be marked with an asterisk.
