Custom DNG processor the the Leica M8, shooting RAW mode and using M8RAW2DNG to produce 14-bit pixels.
Use a Red or Orange filter to eliminate Blue from the image. The Blue channel gets IR only, about 5%~10% efficiency.
Use Histogram Equalization to boost the Blue and Green channels to the same level as Red.
14-bit pixels allow this kind of boost, the crappy 8-bit DNG would look like a contour map.
Swap channels using Tags. Lightroom understands the Tag swap, but most raw processors do not.
View attachment 4839885View attachment 4839886View attachment 4839887View attachment 4839888
SUBROUTINE COLORMOSAIC( IMAGE, COLUMNS, ROWS)
IMPLICIT NONE
C IMAGE GENERATED USING EQUALIZATION.
C 1) COMPUTE HISTOGRAM FOR ALL THREE CHANNELS.
C 2) INTEGRATE ARE UNDER HISTOGRAM AND NORMALIZE.
C 3) EQUALIZE BLUE AND GREEN TO RED.
INTEGER* 4 COLUMNS, ROWS
INTEGER* 2 IMAGE( COLUMNS, ROWS)
INTEGER* 4 COLUMN, ROW
C+++ BEGIN DOS I/O FUNCTION CODES.
INTEGER* 4 MAXPIXEL
PARAMETER ( MAXPIXEL= Z'3FFF')
C HISTOGRAM. STRONGEST WILL BE SET THE THE CHANNEL THAT IS THE FIRST TO
C REACH A THRESHOLD
REAL* 8 INTEGRATION_CUTOFF
PARAMETER ( INTEGRATION_CUTOFF= 0.95D0)
INTEGER* 4 BLUECHANNEL, GREENCHANNEL, REDCHANNEL
PARAMETER ( BLUECHANNEL= 1, GREENCHANNEL= 2, REDCHANNEL= 3)
INTEGER* 4 HISTOGRAM( 0: MAXPIXEL, 3)
INTEGER* 4 BLUEHIST( 0: MAXPIXEL), GREENHIST( 0: MAXPIXEL)
INTEGER* 4 REDHIST( 0: MAXPIXEL), CUTOFF( 3), STRONGEST
EQUIVALENCE ( HISTOGRAM( 0, BLUECHANNEL), BLUEHIST)
EQUIVALENCE ( HISTOGRAM( 0, GREENCHANNEL), GREENHIST)
EQUIVALENCE ( HISTOGRAM( 0, REDCHANNEL), REDHIST)
C INTEGRATE THE CURVE.
REAL* 8 IMAGETOTAL( 0: MAXPIXEL, 3)
REAL* 8 BLUETOTAL( 0: MAXPIXEL), GREENTOTAL( 0: MAXPIXEL)
REAL* 8 REDTOTAL( 0: MAXPIXEL)
EQUIVALENCE( IMAGETOTAL( 0, BLUECHANNEL), BLUETOTAL)
EQUIVALENCE( IMAGETOTAL( 0, GREENCHANNEL), GREENTOTAL)
EQUIVALENCE( IMAGETOTAL( 0, REDCHANNEL), REDTOTAL)
C MAP BLUE TOTALS TO GREEN TOTALS, SHOULD EQUALIZE THE HISTOGRAM.
REAL* 8 GAINCURVE( 0: MAXPIXEL)
INTEGER* 2 BYTES, HANDLE, STATUS, LENGTH, EXCHANGE
REAL* 8 SUMGREEN, SUMBLUE, AVERAGE_GREEN, AVERAGE_BLUE, GAIN
INTEGER* 4 PIXELS, MINBLUE, MINGREEN, MAXBLUE, MAXGREEN
INTEGER* 4 MINRED, MAXRED
INTEGER* 4 I, J, K, L
C FORTRAN METHOD OF GETTING LOW-ORDER WORD FROM A 32-BIT VALUE.
INTEGER* 4 BIGVALUE
INTEGER* 2 VALUE( 2)
C EXTERNALS.
INTEGER* 2 MOD
REAL* 8 DFLOAT, DMIN1
EQUIVALENCE ( BIGVALUE, VALUE)
WRITE( *, *) ' COLUMNS= ', COLUMNS, ', ROWS= ', ROWS
C EQUALIZE BLUE AND GREEN CHANNELS TO RED. CAN CHANGE LATER TO USE
C THE STONGEST CHANNEL.
SUMBLUE= 0.0D0
SUMGREEN= 0.0D0
MINBLUE= 32768
MINGREEN= 32768
MINRED= 32768
MAXGREEN= 0
MAXBLUE= 0
MAXRED= 0
PIXELS= COLUMNS* ROWS
C INITIALIZE ARRAYS.
DO 1 I= 0, MAXPIXEL
BLUEHIST( I)= 0
GREENHIST( I)= 0
REDHIST( I)= 0
BLUETOTAL( I)= 0.0D0
GREENTOTAL( I)= 0.0D0
REDTOTAL( I)= 0.0D0
GAINCURVE( I)= 0.0D0
1 CONTINUE
C COMPUTE HISTOGRAMS AND FIND MAX/MIN OF EACH CHANNEL.
DO 2 J= 2, ROWS, 2
DO 2 I= 2, COLUMNS, 2
BLUEHIST( IMAGE( I, J))= BLUEHIST( IMAGE( I, J))+ 1
GREENHIST( IMAGE( I- 1, J))= GREENHIST( IMAGE( I- 1, J))+ 1
GREENHIST( IMAGE( I, J- 1))= GREENHIST( IMAGE( I, J- 1))+ 1
REDHIST( IMAGE( I- 1, J- 1))= REDHIST( IMAGE( I- 1, J- 1))+ 1
IF( IMAGE( I, J) .LT. MINBLUE) MINBLUE= IMAGE( I, J)
IF( IMAGE( I- 1, J- 1) .LT. MINRED) MINRED= IMAGE( I- 1, J- 1)
IF( IMAGE( I- 1, J) .LT. MINGREEN) MINGREEN= IMAGE( I- 1, J)
IF( IMAGE( I, J- 1) .LT. MINGREEN) MINGREEN= IMAGE( I, J- 1)
IF( IMAGE( I, J) .GT. MAXBLUE) MAXBLUE= IMAGE( I, J)
IF( IMAGE( I- 1, J) .GT. MAXGREEN) MAXGREEN= IMAGE( I- 1, J)
IF( IMAGE( I, J- 1) .GT. MAXGREEN) MAXGREEN= IMAGE( I, J- 1)
IF( IMAGE( I- 1, J- 1) .GT. MAXRED) MAXRED= IMAGE( I- 1, J- 1)
2 CONTINUE
C NOW INTEGRATE THE AREA UNDER THE HISTOGRAMS FOR EACH COLOR.
BLUETOTAL( 0)= DFLOAT( BLUEHIST( 0))
GREENTOTAL( 0)= DFLOAT( GREENHIST( 0))
REDTOTAL( 0)= DFLOAT( REDHIST( 0))
CUTOFF( REDCHANNEL)= -1
CUTOFF( BLUECHANNEL)= -1
CUTOFF( GREENCHANNEL)= -1
WRITE( *, *) ' BLUE= ', MAXBLUE, MINBLUE
WRITE( *, *) ' GREEN= ', MAXGREEN, MINGREEN
WRITE( *, *) ' RED= ', MAXRED, MINRED
DO 3 I= 1, MAXPIXEL
BLUETOTAL( I)= BLUETOTAL( I- 1)+ DFLOAT( BLUEHIST( I))
GREENTOTAL( I)= GREENTOTAL( I- 1)+ DFLOAT( GREENHIST( I))
REDTOTAL( I)= REDTOTAL( I- 1)+ DFLOAT( REDHIST( I))
3 CONTINUE
C NORMALIZE THE CURVES.
DO 4 I= 1, MAXPIXEL
BLUETOTAL( I)= BLUETOTAL( I)/ DFLOAT( COLUMNS* ROWS/ 4)
REDTOTAL( I)= REDTOTAL( I)/ DFLOAT( COLUMNS* ROWS/ 4)
GREENTOTAL( I)= GREENTOTAL( I)/ DFLOAT( COLUMNS* ROWS/ 2)
C LOOK FOR THE 95%.
IF( BLUETOTAL( I) .GT. INTEGRATION_CUTOFF .AND.
1 CUTOFF( BLUECHANNEL) .EQ. -1) THEN
WRITE( *, *) 'BLUETOTAL( ', I, ')= ', BLUETOTAL( I)
CUTOFF( BLUECHANNEL)= I
END IF
IF( GREENTOTAL( I) .GT. INTEGRATION_CUTOFF .AND.
1 CUTOFF( GREENCHANNEL) .EQ. -1) THEN
WRITE( *, *) 'GREENTOTAL( ', I, ')= ', GREENTOTAL( I)
CUTOFF( GREENCHANNEL)= I
END IF
IF( REDTOTAL( I) .GT. INTEGRATION_CUTOFF .AND.
1 CUTOFF( REDCHANNEL) .EQ. -1) THEN
WRITE( *, *) 'REDTOTAL( ', I, ')= ', REDTOTAL( I)
CUTOFF( REDCHANNEL)= I
END IF
4 CONTINUE
C ADJUST THE BLUE CURVE TO MATCH RED.
DO 20 J= 1, MAXPIXEL
C FOR EVERY BLUE INTEGRATED TOTAL, FIND THE RED VALUE THAT EXCEEDS IT.
IF( BLUEHIST( J) .GT. 0) THEN
I= 1
5 I= I+ 1
IF( I .LT. MAXPIXEL .AND.
1 BLUETOTAL( J) .GT. REDTOTAL( I)) GO TO 5
GAINCURVE( J)= DFLOAT( I)/ DFLOAT( J)
END IF
20 CONTINUE
C SCALE BLUE CHANNEL TO RED RESPONSE CURVE.
K= MIN0( MINRED, MINBLUE)
DO 35 J= 2, ROWS, 2
DO 35 I= 2, COLUMNS, 2
BIGVALUE= IMAGE( I, J)
BIGVALUE= INT( DFLOAT( BIGVALUE)* GAINCURVE( BIGVALUE))
IF( BIGVALUE .GT. Z'03FFF') BIGVALUE= Z'03FFF'
IMAGE( I, J)= VALUE( 1)
35 CONTINUE
C EQUALIZE GREEN TO RED.
DO 41 J= 1, MAXPIXEL
C FOR EVERY GREEN INTEGRATED TOTAL, FIND THE RED VALUE THAT EXCEEDS IT.
I= 1
42 I= I+ 1
1 GREENTOTAL( J) .GT. REDTOTAL( I)) GO TO 42
C WRITE( *, *) ' GAIN( ', J, ')= ', GAINCURVE( J)
41 CONTINUE
K= MIN0( MINRED, MINGREEN)
DO 40 J= 1, ROWS- 1, 2
DO 40 I= 1, COLUMNS- 1, 2
C EXCHANGE BLUE AND RED IF NOT BEING DONE IN THE CFA FILTER PATTERN TAG.
C EXCHANGE= IMAGE( I, J)
C IMAGE( I, J)= IMAGE( I+ 1, J+ 1)
C IMAGE( I+ 1, J+ 1)= EXCHANGE
C GREEN PIXEL ON RG ROW
BIGVALUE= IMAGE( I+ 1, J)
IMAGE( I+ 1, J)= VALUE( 1)
C GREEN VALUE OF THE GBGBGBGB ROW.
BIGVALUE= IMAGE( I, J+ 1)
IMAGE( I, J+ 1)= VALUE( 1)
40 CONTINUE
WRITE( *, *) ' FINISHED COLORMOSAIC'
RETURN
END
