santino
FSU gear head
You obviously bought the camera for the lens, right? That Flektogon is a beauty!
Btw. if there is no visible yellow foam in the pentaprism you also got a good shooter.
They are prone to sticky back syndrome but other than them at they are quite a nice lightweight little camera. No meter with manual focus lenses, only downside, but this isn’t a big deal since the viewfinder is set up for AF anyway.Anybody have experience with a Nikon N80/F80? Picked one up for $20 in great shape.
Mine is definitely sticky. Will clean lightly with alcohol tonight.They are prone to sticky back syndrome but other than them at they are quite a nice lightweight little camera. No meter with manual focus lenses, only downside, but this isn’t a big deal since the viewfinder is set up for AF anyway.
One of the best bargains today, I suppose the plastic exterior may be the reason…but it’s the same body that was used in the D100 so it’s well built.
Very nice!
Went to the 90 instead but I understand them to be good. A bit of rubbing alcohol will deal with the sticky back 👍Anybody have experience with a Nikon N80/F80? Picked one up for $20 in great shape.
If you lift the latch when you close the back the plastic lasts a lot longer too.Also picked up an N80 body back in Jan for the same price, had the sticky back and eventually the film door plastic broke on mine (which seems to be a common issue). There is a seller online that sells a metal fix for it
The Praktica MTL5 is my M42 camera for everyday use. I like its simplicity and the bright viewfinder. It is superior compared to the viewfinder of the Asahi Pentax Spotmatic, especially at f4.You obviously bought the camera for the lens, right? That Flektogon is a beauty!
agreeThey are prone to sticky back syndrome but other than them at they are quite a nice lightweight little camera. No meter with manual focus lenses, only downside, but this isn’t a big deal since the viewfinder is set up for AF anyway.
For this amount of money you did very well. The stickiness goes away when wiped with pre-injection swabs.Anybody have experience with a Nikon N80/F80? Picked one up for $20 in great shape.
Dear Kshapero,Anybody have experience with a Nikon N80/F80? Picked one up for $20 in great shape.
Agree. I'm keeping mine despite F100 and F6.They are prone to sticky back syndrome but other than them at they are quite a nice lightweight little camera. No meter with manual focus lenses, only downside, but this isn’t a big deal since the viewfinder is set up for AF anyway.
