Calzone
Gear Whore #1
- Local time
- 11:36 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
Later this morning, I will power walk my “Maggie” for exercise and blood flow. I have the idea of doing intervals doing the climb on Reynold’s Hills on a bike, and doing some muscle tearing, meaning strength training.
I have the task of rebuilding and reinforcing a Guinea Pig shelter that was glued together into something that can withstand the weather for the grand daughter’s deceased pet that is buried in our back-backyard’s memorial.
I have to do a shot for the Peekskill Herald’s 10-Questions series.
The garden is in need of attention, and I have to weed and harvest. Lawn could use a mowing.
With the recent topping off of our oil tank I calculate that annually it costs us $3100.00 worth of oil to keep our winter thermostat at a comfortable and steady 68 degrees. This annual bill is for heat and hot water. The Crown furnace supplies instant on tankless hot water as well as heat to hot water radiators. I find the big and heavy cast iron radiators to be great capacitors for energy storage that kinda provide mass for thermal storage.
This 1912 house lacks insulation, and only wher we remodeled is brought up to code. I upgraded to rock wool for long term performance. Know that our attic has fiberglass insulation that is beyond its service life and has flattened and collapsed to become effectively almost no insulation.
They say 25% of heat is lost through the roof/attic, and I would expect that this would translate into significantly lower heating bills and somewhat to lower cooling bills. Overall our energy costs are well contained.
I need to finish with the baseboard moldings in the dining room. Perhaps I’ll get on that today. The weather has 60 degree nighttime lows, and moderate 80 degree temperatures with moderate humidity. Time to do some work and exercise, and groom the property.
I learned from Andrew a solution of 25% Bleach can act as an herbicide. I need to do this on areas of our brick walkway.
Cal
Cal
