Both really.So, do you think we should aim for imperfection, or just embrace it when it happens? I suspect, given your taste for pictirialism, you will say the former?
I agree with some of what you say - particularly about the invisibility of millions of technically perfect photos. So I am not sure I would say you missed the point. I am not sure I have a specific point other than that maybe photographers should cease chasing technical perfection and instead recognize that photography communicates through the eye and they should instead seek to create images that communicate through visual poetry if I can call it that. (At least occasionally). Perhaps it's "over egging the pudding" to call it eye candy but to some extent that is what good photography is about.There are still great photographers doing great work. They are just buried to invisibility under millions of technically-perfect superficial ones raised to prominence by people of superficial taste. The recognition of the genuinely good things is not a common skill, though in this era it's common to believe that everyone is an expert at everything. Supposedly Georg Solti once told the Chicago Symphony in rehearsal that 95% of their audience had no idea what they were hearing and that the musicians should therefore be giving their best effort for their own gratification.
We now live in a materialist world where the superficial is valued whereas underlying spiritual meanings are intentionally spit on. Thus happens our situation. But you can still have imperfection devoid of meaning; imperfection is just another (contrarian) materialist value in much of this thread--perfect imperfection for the sake of itself, still with no important statement.
peterm1 will probably think I also missed the point, but I don't think so.
@Ko.Fe. , thanks for the Bocharova . That's the real thing!
You have just served up a four-course meal of thoughts. It will take me a while to digest them. 😀Do I put lipstick on the pig a.k.a. overprocessing? Of course I do.
Taken with digital Leica, applied similar to filters you have used for headshot.
Elora Mill Inn... by Kostya Fedot, on Flickr
Contact print from digital Leica via negative printed on regular paper.
Untitled by Kostya Fedot, on Flickr
The layers of imperfection are not limited.
The entry layer is to apply imperfection filters on digital images. Don't make false assumptions. This method examples are on my public Flickr.
It means I do like it.
As person who has grown on visual art from Impressionists it is just natural to have something with "missed focus".
My point is, the entry level approach prevails on photogaphy forums, where most are not into the art, but gearheads approach.
And if picture is not in focus, not framed under primitive rules, not technically right WB, crooked horizon and so on - it is called as imperfection.
To me, as person who has grown on impressionism this is way too simplified approach.
Back to Anna Bocharova photography. She is one of the few making living by photogaphy.
For money, she takes technically perfect product photos with DSLR. After work, she goes on the streets and it takes hours to tune in.
It is not about been in focus, framing and such. It is about starting to feel something inside and starting to react to it.
And she doesn't use digital. Only film and mostly Leica with some slow, old lenses.
I have same thing, I can't go out and shot instantly (I mean I could only do technically fine pictures right away), it takes times and walking distances to start to react on something not too obvious.
Photos often doesn't come anywhere technically perfect. The moment of feel is very short and not predictable.
So, it is always a struggle. Start taking technically fine photos or continue to find something you won't even expect.
Actually, it is one of the Lomography principals. But this days it is gone and replaced by Abu Dhabi style of consumerism.
Well, some are trying to re-live Lomography (originated on cheap film cameras) and using old digital P&S.
Polaroid, Instax is same thing, just more expensive, artsy and original form on technical imperfection 🙂 .
Love this pic.This one taken from the backseat of a 2CV bouncing around on the streets of Palma de Mallorca. The movement tells the story pretty well. Without it the image would be much less interesting to me.
Yes, absolutely. You are a poet at heart, Helen.For some 'Imperfection' is painful to view... a muddled mess
For others a door into the Imagination...
More Emotive, atmospheric beckoning the viewer to pause
be drawn in
Like Attraction
It's more complex than many people can communicate,
It's something you can’t really control.
it just happens
& takes one over
More so when You least expect it
so much of life is all about
what's unsaid ~
Love this pic.
If the 'imperfect' results from over-post-processing, the varnish becomes the furniture and the whole thing falls apart. Cheers, OtLPerhaps it's "over egging the pudding" to call it eye candy but to some extent that is what good photography is about.
I think the process of shooting film is beneficial in recognising when a mistake is a successful one. With digital; you have a vision, you press the shutter, immediately see the mistake and maybe delete the picture. With film, because of the delay, there is more of a disconnect between what you wanted to capture and the result. And you are more likely to see the image for what it is, decoupled from your original intent.
