Räuber
| eBay
Entdecken Sie in der groÃen Auswahl bei eBay. Kostenlose Lieferung für viele Artikel!
www.ebay.de
Clearly the seller has no clue what he has there. This is a Marine Sonnar 5cm f2. It was made for the German Navy during WWII. I don't know if it was used by the Navy. There is an additional engraving on the aperture ring starting with the letters MF (I forgot what that abbreviation stands for). The number is the number of a German submarine. If you find such a lens you can check for what submarine it was produced. Go to the German submarine wiki and look for U xxx.
U 1426 – U-Boot-Archiv Wiki
The numbers I have seen so far where over 1187 and the mentioned submarines where never build. Contax cameras and Sonnar lenses from a submarine that was send into combat are probably extremely rare. A lot of them might be resting on the ground of the Atlantic ocean.
There are collectors of such Kriegsmarine stuff out there. The seller clearly does not know about it or he would have mentioned it in the title. It would generate some interest. And it is no use to contact him since he wrote that the item is in a store and that people should not ask for details. I would be mildly be interested in the MF number. But not so much that I buy this lens.
Photos are a little hit and miss since he let the filter on the lens. I suspect that this lens has no red T and is uncoated. Collapsible aluminum version of the Sonnar with a different construction than the chrome collapsible Sonnars. Very short before the switch to T-coating.
