Räuber
Yes, you are both right. It is no genuine Zeiss Sonnar. Most of the details are wrong. Even the name ring is fake. The serial belongs to a range of lenses that all share the same non-Zeiss origin. German black-market made.
US $418.00Another odd-ball irregular production Sonnar. Looks like a war-time barrel with Zeiss West style of engraving as Rauber has pointed out on other lenses. Serial number does not appear in the 2023 version of Thiele's book of CZJ lenses. Whaddya think?
Carl Zeiss Jena SONNAR 5cm f/ 1.5 in Leica Mount / LTM - Serial Nr. 2870009 NR | eBay
SONNAR 5cm f/ 1.5 Lens. Carl Zeiss Jena Serial Nr. Leica Thread Mount or LTM.www.ebay.com
Some day they will all end up with one person? Draw Straws for it?It sold for less than I thought it would. At the same time, I realize that the number of people interested in antique, potentially historic lenses is decreasing as time passes.
I was sent another Sonnar T transition lens to work on- and made me realize my "276xxxx" lens is mis-engraved, and should be "286". It is nearly identical to the one I just took apart. Some of the 286 batch of lenses ended up as Jupiter-3's, including my perfect glass 1950 lens. That lens is identical to wartime 5cm F1.5 Sonnars, and has the SN in the rear fixture to show it.Another Mystery Sonnar- and part of the mystery solved.
I picked up this 276xxxx 5cm f1.5 Sonnar some 15 years ago, off Ebay- ~$65 or so. Glass is heavily scratched, but bought it as it was "just different".
The front of the lens looks like a typical wartime lens. BUT the rear group and fixture is different. Decided to compare with the Post-War 5cm F1.5 Sonnar. The fixture is different, but the rear group is the same.
Prototype? Scrounge for Parts? The rear group is obviously the same as the post-war production lens.
Rear group is not standard wartime production, different diameter and fixture.
View attachment 4834644View attachment 4834645View attachment 4834646View attachment 4834647
The rear group is the same as the post-war CZJ Sonnar.
View attachment 4834648View attachment 4834649View attachment 4834650View attachment 4834651
